Old 03-17-2008, 09:59 PM   #1
gippy87
gippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-known
Missing cam caps
Back when i didnt know to much about building engines i bought a sr20 head that was ported polished had brian crower springs and retainers i think gave it to a machine shop and had more work done to it. Well im finally ready to put it to good use and i find out i dont have the engines originaly cam caps obviously this is a problem. I do have a set of cam caps from the engines original head, is there anyway i can find out if these cam caps will work obviously they will bolt on but how can i be sure they wont cause a problem with the new cams??
gippy87 is offline   Reply With Quote
Old 03-18-2008, 12:46 AM   #2
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
Just get them checked at the machine shop to see if they will make the cams works. If not they will go right on no problem!
JadeCantDrift Blogspot
i need tires is offline   Reply With Quote
Old 03-19-2008, 01:56 PM   #3
lazierhobo
lazierhobo is on the path to ruinlazierhobo is on the path to ruin
a machine shop will be able to check the tolerances....if they are off you can probably line hone it and get it to work as well....all things a good machine shop will be able to advise you on.
lazierhobo is offline   Reply With Quote
Old 03-25-2008, 05:47 PM   #4
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
gyeah they use like a dial indicator for measuring the I.D. when the caps are installed.. id just use it .
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
