Old 09-07-2019, 07:22 PM   #1
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
Z32 oil press switch work on Sr20?
Anyone know if the z32 oil press switch will work on Sr20 considering swapping over to the two pin connecter?
Will it thread on block and fit?
Dboyizmlg is offline   Reply With Quote
Old 09-07-2019, 07:24 PM   #2
S14rebuild
Yes it will thread in, but why swap it?
Old 09-07-2019, 08:59 PM   #3
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Yes, it will thread, but I am pretty certain they are two different senders/settings more than likely.
Old 09-07-2019, 09:28 PM   #4
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Its my SR swaped Z32, I want to hook this up so that stock z32 oil press gauge will work
Old 09-07-2019, 09:41 PM   #5
S14rebuild
Oh okay, yes sensor will work
Old 11-05-2019, 12:15 PM   #6
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Yes, the Kouki SR20 also uses the same Z32 oil pressure switch to drive the oil pressure gauge. The Z32 has 2 pins, one is a switch for the dummy light in the gauge cluster, the other pin is a variable output for a pressure gauge. I don't remember which is which off hand, but I know I called out the pins in a triple din install thread.
