Old 02-19-2020, 02:51 AM   #1
gripster
gripster is a jewel in the roughgripster is a jewel in the roughgripster is a jewel in the roughgripster is a jewel in the roughgripster is a jewel in the roughgripster is a jewel in the roughgripster is a jewel in the rough
KA KA24E early 9.1:1 pistons
*** 9-9-20 Update ***
Building the engine for daily driver use and SCCA Solo II (autox) rules. As of today:
KA24E
Crank balanced
9.1:1 pistons from Traum Pistons
Cylinder head work by Rebello Racing
Questions:
Which head gasket do i get? What's better than Fel-Pro?
Head gasket bolts? Fel-Pro, Mahle, or ARP? Not exactly a high comp engine.
Which timing chain? Sealed power, Melling, or Cloyes?
*** /update ***
I'm getting a KA24E block rebuilt for my S13 and was looking for the early pistons with slightly higher 9.1:1 compression, part # 12010-40F10.
Late pistons were 8.6:1 compression.
As you can see, these early pistons are NLA/discontinued.
Link: http://datnissparts.com/x-flat-top-p...6-12010-40f10/
Did some digging and found this:
KA24 pistons in L28: https://www.classiczcars.com/forums/...istons-in-l28/
It mentions DNJ P616 flat top pistons.
Has anybody used the DNJ P616 pistons in a KA24E? Oversize also available.
I autox the car for fun and want to keep the sohc OE-spec in case i get competitive and people start protesting. ha ha. right.
Thanks for any input.
71, 72 Celicas; 85 AE88 hatch;
89 S13 hatch; 20 86TRD
gripster is offline   Reply With Quote
Old 02-23-2020, 03:22 AM   #2
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
DNJ is horrible & I highly recommend you do not purchase that brand for anything let alone pistons. Shave a shit out of your head & use a thin head gasket.
s13 @ fullboost is offline   Reply With Quote
Old 09-10-2020, 12:23 AM   #3
gripster
Bump for more questions, like:
For head gasket, besides the OE-spec Fel-Pro, are there MLS (spelling?) or other options to look at?
Old 09-10-2020, 04:11 AM   #4
S14rebuild
Google works....
https://www.google.com/search?sxsrf=...tMPxLGZ0A821:0
Old 09-10-2020, 10:16 AM   #5
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
You should be fine with FelPro and for a stock build I wouldn't worry too much about it.
Is this an HS car? I see DSP in your vehicle description. Just curious.
Old 09-10-2020, 03:01 PM   #6
gripster
FelPro it is then, thanks.
It's been under DSP since 2007. With the head work--waiting to get it back from Rebello--it cannot go back to HS.
Old 09-10-2020, 04:11 PM   #7
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Gotcha.
Good luck taking down the RX8s and E46s
Old 10-26-2020, 09:36 AM   #8
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
mellings chains are good
and I like mahle head bolts on nonboosted engines
The Game
you lose haha
kyral is offline   Reply With Quote
Old 10-26-2020, 09:44 AM   #9
kyral
kyral's Avatar
why don't you like DNJ?
The Game
you lose haha
dnj p616, ka24e, pistons
