Old 11-19-2019, 11:57 PM   #1
Arcedaboss
Arcedaboss is an unknown quantity at this point
s13 sr20det corrected injector??
I have a run ability issue with my sr20det since day one I swapped it..
It idles like crap and dies.. the throttle body response is super laggy.. breaks up under load..
Once I cover the MAF sensor with almost my whole hand it idles better and it actually goes into boost.
Now this has leads me to the injectors being incorrect size for the stock ecu
Not to sure if this are the correct injectors for my s13 sr20det redtop.
Part number looks like
A46-00 08807219
They are red
I looked them up but they are supposedly for a ka24de or a sr20de
But why would some one do this to a det ??? Want to confirm I have the incorrect injector size
Arcedaboss is offline   Reply With Quote
Old 11-26-2019, 03:28 PM   #2
jedi03
why not check that part number against the manufacturer to check flow size...stock iirc is 370cc, stock ecu can only do so much and tune would be needed to run different sized injector...could be person was being cheap and just put on what they had but dunno....
Old 11-26-2019, 04:53 PM   #3
S14rebuild
Pull them out..flow test them....then ull know for sure
Old 11-27-2019, 11:14 AM   #4
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
A46-00 08807219
They are red
Stock Sr20 injectors are PURPLE!!! Not red....
You have incorrect injectors
Dboyizmlg is offline   Reply With Quote
Old 11-27-2019, 11:29 AM   #5
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
lol that happened once on a sr20 we bought. someone had swapped out the stock sr20 injectors for KA injectors. Sneaky sneaky.
Old 12-02-2019, 09:11 AM   #6
jedi03
and then they sold them for 100 lol...I think some of the stock side feeds in other models is the same flow rate, but I don't recall which off the top of my head...I have some 550 sidefeeds if you wna upgrade while you are swapping them!
Old 12-02-2019, 01:19 PM   #7
brndck
brndck's Avatar
yeah stock sr20 are 370.
vg30 are 370 also.
theres a certain year q45 that are 370cc also, iirc.
Old 12-02-2019, 01:28 PM   #8
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
370cc is stock and they are purple or sunfaded grey purple.
and why is because they sell for 100$ a set easy
The Game
you lose haha
kyral is offline   Reply With Quote
Old 12-26-2019, 02:10 AM   #9
Arcedaboss
Yup found the corrected ones
Old 12-26-2019, 02:15 AM   #10
Arcedaboss
So found out that the red ka24de injectors were leaking, which caused my motor to hydro lock..
I took out all the fuel from the cylinders and did an oil change. And got the correct 370cc injectors
Now my car wont start at all. I have fuel compression and spark..
Only thing is that I kinda have weak spark on all coils..
Does the ignitor give out alot on these?
Old 12-27-2019, 08:50 AM   #11
brndck
brndck's Avatar
if you have fuel, compression, and spark, then your timing must be off.
FAST
Fuel
Air
Spark
Timing.
This is the recipe. If you have 3 of those things, then the math says you must be missing the 4th.
When ignitors go bad, they tend to fail completely. I haven't seen a "weak" one before. They're either good or they're bad.
Old 12-30-2019, 01:25 PM   #12
jedi03
did you reconnect ground on the back of the head? tends to be easily missed regularly...is part of the coil pack wire harness
