Old 06-16-2015, 11:35 PM   #1
tunermt
tunermt's Avatar
tunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to behold
Power FC AEM smart coil/LS1,LS2 coil swap Dwell settings
For those of you running Power FC here is a link to explain exactly how to set the PFC coil dwell settings based on Dwell time in ms.
It is very popular to switch out to AEM smart coils or LS1, LS2 coils for a hotter spark when the stock coils just aren't cutting it.
Check out the link below for complete formula for calculating/converting coil dwell in Milliseconds to coil dwell in Crank angle (as required by the Power FC).
http://brewedmotors.com/blog/power-f...coil-swap.html
**Using the Datalogit cable and software**
GTR PartsBuy JDM Cars
tunermt is offline   Reply With Quote
Old 06-20-2015, 09:49 PM   #2
Kingtal0n
Kingtal0n's Avatar
looks like at 5500rpm you start boost creep, is this an internal gate T25 housing turbine?
Old 06-20-2015, 10:53 PM   #3
TheRealSy90
TheRealSy90's Avatar
Thanks for the great info! Anything for using 350z coil packs on sr20?
Such a good signature.
Old 06-20-2015, 11:22 PM   #4
tunermt
tunermt's Avatar
If you know the factory Dwell time for the coils I can set it up no problem for you
Old 06-20-2015, 11:23 PM   #5
TheRealSy90
I guess I'd just have to look that up. Apparently they work great without any changes also.
Old 07-10-2015, 12:49 AM   #6
tunermt
tunermt's Avatar
yes they do work with stock dwell settings but if you don't change the dwell you are missing out and leaving a LOT of spark juice unused.
power fc, power fc sr20det apexi, tuning
