Old 12-04-2019, 06:14 AM   #1
h3avy.t
h3avy.t is an unknown quantity at this point
SR Tapping from engine?!
Hi Guys,
This is a weird one, so my car has developed a tapping noise when just (tiny) a light amount of throttle is being applied - not enough to have any load.
Once you press it a millimeter more(i.e there is even a tiny load on the engine), the tapping goes away?
Can someone point me in the right direction please?? What is going on?
h3avy.t is offline   Reply With Quote
Old 12-04-2019, 08:00 AM   #2
tuzzio
tuzzio's Avatar
Asks about what his engine is doing.
Doesn't state what engine he owns.
Is Sydney the Florida of AUS?
Old 12-04-2019, 09:55 AM   #3
duballstar37
duballstar37's Avatar
duballstar37 is on the path to ruinduballstar37 is on the path to ruinduballstar37 is on the path to ruin
HA! I'll try to help just because of your awesome comment.
Judging by the topic prefix icon, he has a SR.
Does the sound still occur after the car is warmed up?
How many miles are on the engine? Does it sound like its coming from the head or block?
P.A.T.T.
duballstar37 is offline   Reply With Quote
Old 12-04-2019, 01:15 PM   #4
jedi03
get a stethoscope and listen around to see what it could be
Old 12-13-2019, 07:09 AM   #5
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
Turn the engine off so the tapping stops. BOOM. /Solved
If you are a capable human being with some common sense not to stick your hand near moving parts, I would say this.
It seems like something is working it's way loose. I don't mean your camshafts are about to ejecto-seato or anything like that, I am pointing to smaller pieces like heat shields and plastics vibrating.
Some examples below
One of my cars has the alarm horn mounted only by on bolt on the intake. If that was coming loose and rotated, it made a noise similar to knocking.
Another has the air filter assembly mounted together with 4 bolts. PO of the car or whoever changed the air filter last, broke every last bolt head so that the two halves just sit together on the threaded part of the bolt that was sticking out. It vibrates at idle, goes away with RPM.
I would have someone else sit in the car, let it idle and rev it slightly to help you locate exactly where it's coming from.
Cheers
collegekid is offline   Reply With Quote
