Old 07-20-2019, 04:16 PM   #1
Javas13
Javas13 is an unknown quantity at this point
Z32 Maf issues sr20det
New working on cars ended up buying a sr20det s13 anyways. Been working on this car for the past 4 weeks and the last thing is the maf. Ecu is reading code 12. Decided to change the maf to an isr z32 maf and the car dies immediately. The maf before was also a z32 but using the old on the car stays on, idles but only could rev up to maybe 2500 rpms. Not sure if all I need is a tune. Any help would be appreciated thank you.
Javas13 is offline   Reply With Quote
Old 07-20-2019, 04:20 PM   #2
Javas13
Here's a video of using the new isr maf
https://youtu.be/xon1PQl9ftA
This is how it ran before the change
https://youtu.be/TglbWysbMFY
Old 07-20-2019, 05:40 PM   #3
ultimateirving
ultimateirving's Avatar
Could be that wiring is slightly different. Check the signal wire and 12v matches the new MAF.
Z32 with lq4 swap
Old 07-20-2019, 05:57 PM   #4
Javas13
Just checked wiring is good but my 12v is only getting 11v and the 5v is getting .90v for some reason
Old 07-21-2019, 07:10 PM   #5
S14rebuild
What are you tuning with to allow the sr20 to run a z32 maf?
Old 07-21-2019, 10:12 PM   #6
Javas13
Not sure still new to all this. I bought the car this way already. I was planning on taking it to a tuner hopefully this week
Old 07-22-2019, 12:37 PM   #7
ultimateirving
What’s the part number on the old maf
Z32 with lq4 swap
Old 07-22-2019, 01:14 PM   #8
Javas13
Not sure car came with it only numbers that are on it is 1504 but here's the differences between the old and new one
https://ibb.co/cNkzbcW
https://ibb.co/yPD6gFt
https://ibb.co/v470h5G
https://m.imgur.com/gallery/IK1tN2x
Old 07-22-2019, 03:08 PM   #9
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
ummmmm the one on the left only has 4 prongs
the one on the right has 5
this concerns me.
Old 07-23-2019, 12:34 AM   #10
Javas13
this concerns me.
Yea me too. I ordered one off import image in their pictures it looked Identical to the old one I have so I ordered it but they sent another isr 4 pin one. So I'm talking to their support to see what's up
Old 07-24-2019, 01:56 PM   #11
gaz_moose
gaz_moose is an unknown quantity at this point
is your new one genuine?
gaz_moose is offline   Reply With Quote
Old 07-24-2019, 03:02 PM   #12
Javas13
No that's my next list of things to try. Im picking one up tomorrow
Old 07-25-2019, 09:30 AM   #13
jedi03
when i was having tuning issues with enthalpy turned out my maf was bad, brand new from autozone...he advised they are hit or miss but got me up and running...
Old 07-28-2019, 03:39 AM   #14
Javas13
So far I've tried 3 different mafs two isr mafs and one oem all do the same but the on I had on the car when I purchased it. That's the one that keeps the car idling fine but doesnt rev passed 2500
Old 07-28-2019, 12:42 PM   #15
brndck
brndck's Avatar
Mmmmmmmmaybe you should check your wiring instead?
Old 07-29-2019, 09:46 AM   #16
jedi03
+1 check all wiring, make sure ecu isn't fried and last get retune...
Old 07-29-2019, 11:00 AM   #17
Kingtal0n
Kingtal0n's Avatar
If engine RPM stops at 2500
that means the ECU does not see ANY MAF AT ALL (its like having no maf)
Old 08-05-2019, 03:54 PM   #18
ultimateirving
So consider with the new maf plugged in, are there any leaks ? If it’s reading the maf but had a bad vacuum leak it will run like poo
Z32 with lq4 swap
Old 08-15-2019, 10:49 AM   #19
EFITTZY
EFITTZY's Avatar
EFITTZY is making a name for him/her selfEFITTZY is making a name for him/her self
Just for reference use the jim wolf diagram
http://jimwolftechnology.com/wolfpdf...%20NISSANS.PDF
(づ。◕‿‿◕。)づ T E A M B L O O M
EFITTZY is offline   Reply With Quote
Old 08-21-2019, 10:34 AM   #20
jedi03
http://www.sr20forum.com/240sx/12922...af-sensor.html or this one if pictures help better!
