Old 12-13-2017, 03:01 AM   #1
Measuring
Measuring is an unknown quantity at this point
s13 One highbeam not working
Hello!
I've noticed that my left high beam doesnt work on my s13. Both lowbeams work great but when I flip the highbeams on. The left headlight goes black and the right one works just like it should.
Any idea on why this might be happening?
Thanks
Measuring is offline   Reply With Quote
Old 12-13-2017, 10:14 AM   #2
gaz_moose
gaz_moose is an unknown quantity at this point
check the small headlamp looms haven't melted.
gaz_moose is offline   Reply With Quote
Old 12-13-2017, 10:39 AM   #3
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Switch the headlights, that will let you know if it's the filament or the wiring.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 12-13-2017, 06:01 PM   #4
gtrpryde
gtrpryde is an unknown quantity at this point
I had a similar problem. I ended up rewiring the lights with a new relay off the "good working" low and high beam, rather than try and track down a short in the wiring.
gtrpryde is offline   Reply With Quote
electrcial, headlight, light
