Old 04-14-2014, 10:39 PM   #1
Jdmfreak078
Jdmfreak078 is an unknown quantity at this point
Rb20 oil cooler
Before opening the thread, i tried searching for an rb20 oil cooler, all i was getting is a greddy oil cooler and oil filter relocation kit which i only want is the oil cooler.
So help me to find one for my rb20.
And what brand you guys suggest? Any of you running one?
Any help would be appreciated.
Using Tapatalk
Jdmfreak078 is offline   Reply With Quote
Old 04-14-2014, 11:26 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Wellllll just run a sandwich block then, with fittings for a cooler.
Like this
http://www.240sxmotoring.com/mishimo...il-cooler-kit/
Personally I have no experience with mishimoto, but this is the style you're looking for. Ideally one with a built in thermostat inside the sandwich plate.
Old 04-14-2014, 11:31 PM   #3
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
I know this is for a sr20 build, but I used pretty much the same parts as the op did in his write up. Only thing you need is the sandwich plate adapter that will fit your motor.
http://zilvia.net/f/showthread.php?t=198621
eek is offline   Reply With Quote
Old 04-14-2014, 11:36 PM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You should be able to use KA sandwich block since KA and RB uses the same oil filter snout, atleast on RB25s they do.
CLICK HERE!!!
Old 04-15-2014, 01:13 AM   #5
Jdmfreak078
Thanks guys! Appreciate it!
Using Tapatalk
Old 04-15-2014, 07:32 AM   #6
wowzers9930
wowzers9930 is an unknown quantity at this point
Here is an awesome thread I used, I changed it up a little using a summit cooler and using -8 AN lines instead of what he uses -6 I believe...
http://www.nicoclub.com/archives/rb2...tallation.html
wowzers9930 is offline   Reply With Quote
