Old 04-07-2014, 01:05 AM   #1
JDMBart
Banned from the Marketplace
Trader Rating: (-1)
JDMBart is an unknown quantity at this point
Feedback Score: -1 reviews
Ignition fuse keeps blowing
Need help, my 30 amp ignition fuse keeps blowing.
Where should I start looking for problems?
JDMBart is offline   Reply With Quote
Old 04-07-2014, 04:58 AM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You should start by looking at the wiring diagram.
CLICK HERE!!!
Old 04-07-2014, 07:51 AM   #3
venom2034
venom2034 is an unknown quantity at this point
What was the last thing you did before this started to happen? The wiring diagram will help you narrow down where the short is by letting you know what parts are connected to that fuse. You don't waste time looking at another portion that isn't even connected to what you're looking for. And as far as your problem goes, something must be grounding out, possibly a pinched wire or if you did wiring then something was hooked up wrong.
venom2034 is offline   Reply With Quote
Old 04-07-2014, 10:08 AM   #4
JDMBart
Trader Rating: (-1)
Never had this problem until yesterday, I replaced my battery terminals and I replaced a couple tail light bulbs, but that couldn't be related to the ignition fuse right?
Sent from my SPH-L720 using Tapatalk
Old 04-08-2014, 05:53 PM   #5
JDMBart
Trader Rating: (-1)
UPDATE: Turns out I rubbed the harness that runs next to the front wheel when I lowered my coils. fixed the insulation on the worn wires, popped in a new fuse and I'm good to go! Also relocated the harness so I dont have this issue in the future.
Old 04-09-2014, 07:09 AM   #6
venom2034
awesome, make sure you tuck it real well and zip tie it up there. I'm sure that has happened to everyone of us on this forum.
