03-26-2020, 07:12 PM | #1 |
RB26 assembled engine + transmissiom
Got a couple things for sale first is a
Rb26 out of a R32 GTR. Completely refreshed, all parts brand new and never ran unless stated. $6650USD if you think the price is high go buy a unknown condition motor from an importer for $4500USD Engine has been completely refreshed and blue printed. Crank measured, bores, runout, thrust, rings gapped, cam clearance ect.. pictures of everything and all measurements can be supplied. including compression test 160-162psi across all 6, 3-5% leak down test across all 6. Standard bore 86mm OEM/piston rods All parts are brand new ACL Main and rod bearings. N1 oil pump (backplate screws lock-tited) New OEM Water pump (15,000km) Nitto Crank collar and set screws installed Oil pick up seal Rear main seal Oil cooler gasket Tensioners and timing belt Head OEM cams All brand new Valve job Valve seals Valve guides Cam cover seals Half moons Tomei 1.2mm head gasket Nitto metal throttle body gaskets Head Resurfaced Arp head studs Brand new Nissan coil packs ($600 alone for these) Fresh bcpr7es spark plugs. New silicone hoses under intake manifold. This motor comes with everything seen in pictures; ignitor, CAS, full intake manifold and vacuum setup. Motor Mount brackets, alternator, power steering bracket, iacc,aacv,tps,knock sensors. Stop running cheap couplers and shitty T-bolt clamps that pinch the coupler and leak. 4x - 3" vibrant 4 ply couplers #2714 retail $20cad/each 1x - 3"x2.5" vibrant 4 ply reducer #2772 retail $50cad 10x - breeze CT-350 constant torque clamp retail $12cad/clamp Take it all for $120cad ($85usd) Also have 2 R32 GTR push style transmissions for sale. They can be converted to a pull style with no extra parts if you already have a pull style transmission and are just looking for a spare to have. no grinds or anything $800cad($560usd) each. Inspected and gears are great shape Willing to ship everything under buyers expense. Sent from my Pixel 2 XL using Tapatalk
