Old 09-23-2011, 09:19 PM   #1
ImpatientS14
ImpatientS14 is an unknown quantity at this point
1995 240sx SR20DET GT30R AEM EMS 450hp
Moving on car is $8,750 obo. Very motivated seller.
Drivetrain
Redtop SR20DET (2.2 Liter)
Greddy Oil Pan
Darton Sleeves Bored to 90mm
Eagle Rods
CP Pistons
Calico Race Bearing (Crank & Rod)
New Oil Pump
Mazworx 90mm Headgasket (Copper Coated)
Comp Valve Springs
Crower Valve Spring Retainers
BC 272 Camshafts
HKS Rocker Arm Stoppers
Valve Cover Powder Coated Wrinkle Black
Real Greddy Intake Manifold (Powder Coated Wrinkle Black)
AEM 3.5 Bar Map Sensor
AEM Air Temp Sensor
Holley 80lb/Hr Top Feed Injector
Custom Top Feed Fuel Rail
Aeromotive Fuel Pressure Regulator
Aermotive Fuel Filter
2x Walbro 255lph Fuel Pumps
Aluminum Radiator
2x Electric Fans
Samco Silicon Hoses and Couplings
Spec Oversized Clutch and Flywheel
B&M Short Shifter
J30 Rear End
Wiretuck
Turbo
Precision GT3076R
Heat Blanket for Turbo
4” Intake w/K&N Filter
Tial Wastegate
Blitz BOV
Front Mount Intercooler
Custom Exhaust Manifold (Heat Wrapped)
3”Downpipe (Heat Wrapped)
Full 3” Apex N1 Exhaust
Electronics
AEM 30-1601U EMS
AEM Serial Data Gauge
AEM TruBoost Controller/Gauge
SplitFire Ignition System/COP
Chassis
Nismo Motor Mounts
Momo Competition Steering Wheel
NRG Short Hub
NRG Quick Release
Line Lock
Optima Redtop Battery
Chassis Harness Tucked under dashboard
BS Lowering Springs
Cusco Traction Bars
Nismo Shift Knob
Last edited by ImpatientS14; 10-22-2011 at 04:05 PM.. Reason: Price lowered for quick sale.
ImpatientS14 is offline   Reply With Quote
Old 09-28-2011, 01:58 PM   #2
ImpatientS14
Price lowered to 10,000.
Old 09-28-2011, 04:59 PM   #3
ZenkiLB
ZenkiLB is an unknown quantity at this point
More pictures please.
ZenkiLB is offline   Reply With Quote
Old 09-28-2011, 06:42 PM   #4
ASIXMRSE
ASIXMRSE is an unknown quantity at this point
bump for more pictures
ASIXMRSE is offline   Reply With Quote
Old 09-29-2011, 08:07 PM   #5
ImpatientS14
Front
Back
Side
Inside
Dashboard
Old 09-29-2011, 08:10 PM   #6
ImpatientS14
Gauges Linelock and 2step switches
Engine
Sleeved and Bored
Wiretuck
Old 10-01-2011, 07:33 PM   #7
ZenkiLB
Who did the wiretuck?
Old 10-02-2011, 07:02 PM   #8
ImpatientS14
I did. Used Insultherm to loom the entire harness in the enginebay and everything else is tucked under the dash, with the chassis fuse box mounted with access through the passenger air bag door.
Old 10-04-2011, 02:01 PM   #9
Drftr915
Drftr915's Avatar
Trader Rating: (22)
Drftr915 is an unknown quantity at this point
Feedback Score: 22 reviews
This might be a dumb question, but how can it be a 2.2 without a different crank?
Drftr915 is offline   Reply With Quote
Old 10-04-2011, 08:36 PM   #10
ImpatientS14
Because to bore has been increased to 90mm and the stroke has not been changed. You can also stroke the motor, Brian Crower has a kit, and it will then be about a 2.4 liter.
Old 10-10-2011, 07:58 PM   #11
ImpatientS14
Bump, really looking to sell this car.
Old 10-11-2011, 01:33 PM   #12
ImpatientS14
Price lowered to $9,000.
Old 10-13-2011, 10:57 AM   #13
The_Other_Aaron
The_Other_Aaron is an unknown quantity at this point
Have you dynoed the car or is 450 just an estimate? Also was the work done by yourself or a shop? Receipts for any of the build?
The_Other_Aaron is offline   Reply With Quote
Old 10-13-2011, 08:57 PM   #14
96rbs14
96rbs14 is an unknown quantity at this point
^^^^^^^^ what he said^^^^^^^^^ clean clean car pm me bottom dollar
96rbs14 is offline   Reply With Quote
Old 10-13-2011, 09:12 PM   #15
ImpatientS14
Car was on the dyno and tuned on the dyno which made 420hp at 20psi. Car is still running the same tune, but the motor setup is different because the block had a small crack in the sleeve of #1, which is why the block is sleeved now and bored to 90mm. I estimate that the new setup and a healthy motor should put it around 450 if not higher. Can be tuned to whatever you like, weakest link in the block is the Eagle Rods which are supposed to be good for up to 600hp.
The original setup was done by a shop as was the tune. This motor was assembled by me in my garage. I am particular about things so I didn't want to leave the build up to a shop that could cut corners. I took my time putting the motor together and using only good parts.
Sleeves were installed by Darton.
Old 10-19-2011, 08:18 PM   #16
ImpatientS14
Bump it back to the top.
Old 10-22-2011, 04:05 PM   #17
ImpatientS14
Price lowered tp $8,750.
Old 10-22-2011, 05:29 PM   #18
Urotrsh
Urotrsh is an unknown quantity at this point
Interested in trades? Got a stanced 96 ls400
Urotrsh is offline   Reply With Quote
Old 10-23-2011, 12:24 AM   #19
wagonkilla
wagonkilla is an unknown quantity at this point
sr20det
Part engine?
408-417-5766 let me know
Very serious
wagonkilla is offline   Reply With Quote
Old 10-25-2011, 08:15 PM   #20
ImpatientS14
Sorry no trades, planning on picking up a new vehicle. Not interested in parting the engine, but if you buy the motor for $8750 I'll throw in the car for free.
Old 10-31-2011, 03:50 PM   #21
ImpatientS14
Accepting reasonable offers. The current price is so cheap considering the motor set up cost this more than the asking price alone. Bump.
Old 11-02-2011, 01:11 PM   #22
Fresh2Death
Fresh2Death is an unknown quantity at this point
Are the air lines still in it to eventually put heat and or air back on it ?
Fresh2Death is offline   Reply With Quote
Old 11-02-2011, 05:10 PM   #23
ImpatientS14
Everything ac/heat related is gone.
Old 11-03-2011, 06:16 PM   #24
325iturned240
325iturned240 is an unknown quantity at this point
sell pending!!!
325iturned240 is offline   Reply With Quote
Old 11-19-2011, 08:53 PM   #25
325iturned240
sold!!!! thanks again man, I'll let you know how she's doing soon haha
