11-12-2014, 11:23 PM | #1 |
redtop with power fc d-jetro has horrible accelertion
need some help from the smart ones here...
redtop rebuilt power fc d-jetro gt2860 hks 550's isis intercooler greddy intake mani megan exhaust mani, downpipe, exhaust, elbow hks bov tomei 256 cams so far have checked or changed, tps, knock sensor, coolant temp sensor if there was a bad sensor wouldnt the pfc pick it up? does it target the tps voltageand correct timing? have had my car up to PSI 2 times now to have it tuned and each time i pick it up "its good to go" but it does not accelerate for s**t. If im standing at the car and its at operating temp with my afr's at around 14.x idling, and i stab the throttle i can literally get the car to die?? i can "pump up" the throttle sort of speak like and old chevy thats geting flooded. has anyone had this problem before or know who to turn to? any feedback is much appreciated *again standing in the front or sitting in the car i can punch hit stab step or push the throttle the car wants to die and if i let it idle and quickly open the throttle i can actually get the car to die??? in gear or in neutral* |
11-13-2014, 11:34 AM | #2 |
It needs tuning, or something (like your fuel pump) is failing, or there is an air leak,
take some pictures of it. And send me a picture of the fuel map / timing map. Do you have a wideband. This is essential, no tuning can be done without it (unless you are experienced) |
11-13-2014, 12:02 PM | #3 |
ed above have had it tuned 2 times and at a very reputable shop psi (PORTLAND SPEED INDUSTRIES) and my air fuel ratios are right at 14.xx at idle and float open to 11-10.5 at WOT and i know this cuz i have a wideband.. i am not experienced with the power fc tuning thats why im asking for help??
this was all put in the posting? |
11-13-2014, 02:16 PM | #4 |
lol, if you hit the gas pedal, and engine wants to die... it needs tuning. Or you have a mechanical issue, or an electronics issue. Also WOT A/F should be around 12:1 unless you are running 400+ horsepower 20PSI of boost or more. Since you have PFC I assume you have COMMANDER. So open the fuel table, the idle portion, take a picture of it. When you stab the gas pedal from idle, it will sit at the 10000 mark, 9500 on a maf car. Thats 10 boxes down from where it starts.
A good tuner is also a good diagnostician, which means whoever tuned the car would invariably hit the gas pedal and notice the engine want to die. So this makes me wonder who left it like that? |
11-13-2014, 02:37 PM | #6 |
he sure did.. and both times i brought it back was for the same sluggish to no acceleration or rev issue which now seems worse after the last time i picked it up? Hes awesome and a super cool guy to deal with. i was just ultimately wondering if anyone else has ever had this problem cuz i hate being the return customer who complains about their car. But it really doesnt run correctly. my stock sr in my other car would dust my cool guy fixed up sr
correct i would assume he would notice that but both times ive had the same exact problem when i get the car back. plus PSI is 2 hours from me so its not like i can just run it down there its usually a 6 hour round trip. |
