Old 03-05-2019, 07:27 PM   #1
Jeff Taylor
Jeff Taylor is an unknown quantity at this point
FS: 1996 Nissan 240sx with 819wHP VH45DE-T
I am sad to say that I am letting go of my 1996 Nissan 240sx. This car has been lots of fun. After finding the stock-internal limit of my VH45DE to be 819wHP, and watching the rotating assembly put 2 holes through the engine block, I have not had the time to swap another engine back in. The car basically went straight from the dyno room back into my garage, where it has sat for 8 years now. :frown:
The engine's internals were ALL stock, so swapping in another used stock engine should be all it takes.
Anyway, here's the high-level specs:
Engine: Infiniti Q45 V8 (4.5L, DOHC, ALL STOCK)
Transmission: 300zx twin turbo 5-speed
Clutch: SPEC stage 5 sintered iron disc
Transmission Adapter: Water-jet cut adapter plate, milled bell housing
Engine & Trans Mounts: Custom, solid steel mounts
Turbo: Garrett 72mm from a Detroit Diesel engine,
60mm wastegate with external dump
Intercooler: 24” x 12” x 3” fed by 3” mandrel-bent tubing
Fuel: E85 or 93 octane
Engine Management: AEM EMS, Low-Impedance Injector Driver Board
Fuel Injectors: 150 lb/hr low-impedance
Fuel Pumps: 3 parallel in-tank Walbro 255HP's staged at boost levels
Fuel System: -10AN Feed to Aeromotive fuel pressure regulator
Cooling system: Radiator relocated to trunk to make space for turbo
Driveshaft: Custom
Intake Manifold: Custom, CAD CFD-Designed, short-runner, balanced plenums
Exhaust Manifolds: Stock tubular manifolds re-designed to point forward
Exhaust: 4” Diameter w/ resonator & muffler
Rear End: Stock, welded spider gears
Interior: 10 point 1-3/4” roll cage
Included Extras: Many extra Nissan parts in my garage! I have a lot!
Power: 819 wHP / 727 wTQ @ 20psi boost (stock rods broke)
759 wHP / 685 wTQ @ 18psi boost
Pictures/Info: https://drive.google.com/open?id=16_...oySHgl-askfJe4
Keep in mind the car has been sitting for 8 years in my garage. It is dusty and dirty. This car is the opposite of a "show car", but I have never been one for body work.
Last dyno pulls:
https://www.youtube.com/watch?v=u-UqJUbkNi0
https://www.youtube.com/watch?v=EWbqrM5VTrY
https://www.youtube.com/watch?v=G86ThQ8yJ2M
Jeff
Jeff Taylor is offline   Reply With Quote
Old 03-05-2019, 10:10 PM   #2
95_S14
95_S14's Avatar
Trader Rating: (108)
95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future
Feedback Score: 108 reviews
Price..........
Www.PowerAutosports.com
95_S14 is offline   Reply With Quote
Old 03-06-2019, 07:20 PM   #3
Jeff Taylor
Asking $6,000 OBO. Swap in another $200 used engine and let 'r eat again! Includes car and many Nissan-related extra parts.
See profile for my email address.
Jeff
Old 03-07-2019, 02:49 PM   #4
Krazykouki
Krazykouki is making a name for him/her selfKrazykouki is making a name for him/her self
6k for a busted looking shell...I've officially seen it all now.
Krazykouki is offline   Reply With Quote
Old 03-07-2019, 02:58 PM   #5
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
so, if im reading this correctly. the car still has the broken rods in it (and possibly two holes in the block)? therefore the car is no longer making 819 hp.
it makes 0 hp.
jumpman2334 is offline   Reply With Quote
Old 03-07-2019, 07:58 PM   #6
Jeff Taylor
That's right. So, how can I get you into this car today? How about I top off the fuel tank for you or shine the flat tires it sits on?
Sent from my SM-G930VL using Tapatalk
[email protected]
Old 03-09-2019, 02:26 PM   #7
Jeff Taylor
Now asking $3000 OBO
[email protected]
Old 03-09-2019, 03:05 PM   #8
afishysilvia
afishysilvia's Avatar
Trader Rating: (31)
afishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfection
Feedback Score: 31 reviews
Welp this dropped significantly fast.
Dont be a pussy...Leave your name
afishysilvia is offline   Reply With Quote
Old 03-09-2019, 08:51 PM   #9
Mr Miyagi
Mr Miyagi's Avatar
Mr Miyagi will become famous soon enoughMr Miyagi will become famous soon enoughMr Miyagi will become famous soon enoughMr Miyagi will become famous soon enoughMr Miyagi will become famous soon enough
wtf looool that price drop
Mr Miyagi is offline   Reply With Quote
Old 03-18-2019, 06:10 PM   #10
Jeff Taylor
Now $2,000 OBO. Here's some pictures of the condition it's in.
https://drive.google.com/open?id=1-C...MfENIGwHrZ2tYm
Price includes any other Nissan parts I have in my garage (MAF's, injectors, ECUs, engine heads, alternators, PS pumps, AC compressors, starters, etc). The garage needs to be cleaned out!
[email protected]
Old 03-18-2019, 10:28 PM   #11
AzDRiFT
AzDRiFT's Avatar
AzDRiFT is an unknown quantity at this point
Send a message via AIM to AzDRiFT Send a message via Yahoo to AzDRiFT
Dibs. Sent you a PM sir.
AzDRiFT is offline   Reply With Quote
Old 04-04-2019, 02:20 AM   #12
Farzam
Farzam's Avatar
Curious if this is sold and how obo it is lol
Farzam is offline   Reply With Quote
Old 05-07-2019, 07:31 AM   #13
jdm60
jdm60's Avatar
jdm60 is on the path to ruinjdm60 is on the path to ruin
Is this still for sale?
jdm60 is offline   Reply With Quote
Old 05-29-2019, 07:36 PM   #14
Rcurriemusic
Rcurriemusic is an unknown quantity at this point
Still available?
Rcurriemusic is offline   Reply With Quote
