![]() Join Date: Jul 2010
Trader Rating: (-1)
![]() Feedback Score: -1 reviews
![]() Name: Brian
Location: Va Beach Means of contact: 9152745717 text me for pictures Price $11k or trade for STI or IS300 Description: -Rb25det transmission (broke the rb20 one and the rb25 one can handle 700hp no problem) -Stock ECU with Nistune Real time tunning board -Top speed tubular top mount exhaust manifold -Hybrid turbo a/r 60 comp and a/r 50 exhaust 22 pounds no smoke -Z32 maf -555 dsm injectors -Tial wastegate -Aem wideband -spec stage 2 clutch ( also just installed new clutch master cylinder) -Aerommotive FPR/ SARD Fuel Rail Adapter -Walbro 255 fuel pump -2.5 down pipe and full 2.5 hks hi power exhaust -Front mount Intercooler --HKS BOV -Aluminum radiator wit dual slim fans (pushers) -Nismo Thermostat -Aluminum Intake Manifold with velocity stacks inside -90mm aluminum throttle body Just recently installed tomei pon cams, new cometic hg, arp head studs, new crank seals, powder coated spark plug cover, new timing belt, tension and pully, new water pump, custom dump pipe, catch can/breather system and tuned by matt shue at adrenaline autoworks this past FEBUARY was tuned at 419 whp at 19psi. **just changed the oil with REDLINE 5w-40 synthetic** Body Car was painted in MARCH 2010 at a BMW PAINT SHOP that paints upper end cars all day long BMW and Lexus mostly. -Fresh paint job (Daytona Blue) -Shaved ugly antenna -clear headlights w/ 6k hid's -Fresh under coating -No dents -No Rust -No body Damage Suspension This car has allot of suspension upgrades. Not just rims but Suspension arms, great coilovers and brake upgrades -17" ASA AR-1 (5 x 114.3) Fronts: 17x7 (offset 38) falken 452 Rears: 17x8 (offset 35) falken 452 -Front extended lug studs and 20mm hub centric spacers -Tein Type Flex Coilovers (retail over $1500) -Tein tie-rods -Tanable Sustec 1-Rear Upper Control Arms 2-Toe Rods (Rear) 3-Rear Upper link 4-Front Under Brace -Aftermarket Adjustable Front Tension Rods -DC front strut tower bar -Cusco carbon fiber rear strut bar -Rear sub frame spacers -Z32 300zx 30mm Rotors and Calipers to stop the car better.(bigger rotor/caliper Four Piston) Steel braded brake lines up front also. -z32 brake master cylinder -Front adjustable tension rods Interior Cool stuff -Apexi SAFC-II black flush mounted below the radio -A pillar gauges Aem wideband and Cobalt Boost/Vac -Above radio center of dash three gauge pod Cobalt Oil Pressure and Cobalt Water Temp. just bought and egt guage will be installed soon. . .Climate controls relocated to glove box Audio Equipment -Kicker kx650.4 (4 channel amp) -pioneer headunit with ipod cable -Kicker SS 8" mid and 30mm SS tweeters with crossover in front door -Kicker RS 6.5 component speakers in rear with crossover -jl audio 10in sub in rear with its own amp -All new speaker wire ran - Battery Relocated to trunk. Optima yellow top. Clean relocation job used power distribution block up front, 0awg wire using fuse holder to make everything safe. Also in battery box tied down with good grounds. - 4guage wire ran to separate fuse holder than to amp Security -Alarm with keyless entry/ remote start/ turbo timer (python 990). Very nice alarm 2-way transponder SST technology aka works from a good distance. Blue led lights to warn off scum. Also included but not yet installed -complete master bushing set - I am sure I have more stuff that goes with it just cant remember. -power steering pump and bracket -A/C pump and bracket The Bad -needs power steering put back on and i have the pump -does not have a/c but can be put back on and i have the pump - speedo reads double what it should because when the stock tranny died and when I purchased the rb25 tranny it didn't have a speed sensor so I used one from a 300zx and the gear is different size so it reads higher( a digital speedo interface box from Dakota digital will fix this..its less than $100 and easy to install) -small ding in the passenger side corner bumper about the size of a credit card Last edited by Brian BK; 10-14-2012 at 06:12 PM.. Reason: price drop! |
#8 |
Seen this car in person, looks amazing, sounds amazing. sorry to hear your selling it brian. its Mike with the black rb s14, we met while i was swapping out the turbo. number changed. and im out of the counrty. lol
#9 |
Im pretty sure when i installed the fans a thermostat was used and the "ghetto rigged switch" was placed next to the temp for a fail safe also wired in with a relay like the thermostat. Unless it has been changed around....?
PimpN My 240 Daily! ![]() |
#12 |
Could you email me some more pics if you have them? I appreciate it! [email protected]
rb20, s14 240sx 95, turbo |
