Old 09-22-2020, 09:53 AM   #1
DonVaughnS13
DonVaughnS13 is an unknown quantity at this point
Catch Can Setup Problem
Hello fellow Zilvians,
I've searched and been through much of the catch can setup threads. Because of their age most have missing photos/broken links/scattered information.
I currently have a stock SR20DET setup with a new ISR air intake. I'm looking to add a catch can setup however there is no bung for the return line from the catch can after the MAF in the piping. I read this is where the line should go from the catch can.
Is there an alternative solution to successfully setting this up? I'm already aware of how to set much of it up, I just seem to have difficulty figuring this out.
Thank you in advance.
DonVaughnS13 is offline   Reply With Quote
Old 09-22-2020, 10:27 AM   #2
S14rebuild
Add a fitting to the intake... hose barb or an fitting......
Old 09-22-2020, 10:30 AM   #3
DonVaughnS13
Thanks. That is my first idea. However I read there is a restrictor on the stock intake piping. I have not been able to find this fitting online. Is this restrictor required?
Old 09-22-2020, 10:32 AM   #4
S14rebuild
Some will say yes, so will say no. Not to hard to add a fitting in the hose to act as a restrictor.
Old 09-22-2020, 10:41 AM   #5
DonVaughnS13
Thank you for your help!
Old 09-22-2020, 10:49 AM   #6
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
That's a subjective question. Like S14 said, some do it as a precaution while others swear by it and then there is the crowd that doesn't do it at all. It's personal preference but adding an attachment point is suggested.
SupaDoopa is offline   Reply With Quote
Old 09-22-2020, 10:46 PM   #7
Kingtal0n
Kingtal0n's Avatar
If you put a restriction on the hose and fail to measure crankcase pressure while cruising and at idle you run the risk of pulling too much vacuum on the crankcase which will pull all the oil seals into the engine i.e. damage the front and rear main seals. which of course means rebuilding the engine.
So if you dont plan to measure the crankcase pressure properly using a gauge (it should measure approx 2-3" of Hg maximum at all times) then do not use a restrictor at all just leave the hose open.
this will ruin the effects of PCV pressure drop but it will remove any concerns over whether the oil seals will be damaged.
Old 09-23-2020, 08:48 AM   #8
DonVaughnS13
Thanks all, it's really appreciated.
Old 09-23-2020, 10:18 AM   #9
TheRealSy90
TheRealSy90's Avatar
Wouldn't a restrictor on the hose lower the vacuum applied to that hose...
Such a good signature.
Old 09-23-2020, 01:00 PM   #10
d1zguy2
d1zguy2 is an unknown quantity at this point
The PCV side left side of the VC is the one that provides vacuum, not running the right side to intake pre maf will cause a lean condition and no vacuum in the crank case. the restrictor is there to prevent sucking up oil but running a closed catch can is and routing it to the intake pre maf is all you need, the restrictor on the stock hose is there to prevent sucking up actual oil. With a closed catch can you don't actually need it.
d1zguy2 is offline   Reply With Quote
Old 09-23-2020, 04:48 PM   #11
Kingtal0n
Kingtal0n's Avatar
wrong. the restrictor has nothing to do with 'sucking oil'. Look at where it is positioned.
please read
https://www.sr20-forum.com/informati...on.html?page=1
From Ben,
Originally Posted by BenFenner
Without it, idle air is less controllable, and the crank case can't ever really hold a vacuum at all.
Repeat: the restrictor is there to assure the crankcase can hold a vacuum
Old 09-23-2020, 05:50 PM   #12
d1zguy2
please read
From Ben,
Well that makes sense. I?ll have to see where the restrictor is so I can replace it when I install a closed catch can. Is it on the stock rubber boot or the stock hose?
Old 09-23-2020, 08:04 PM   #13
Calver
Calver is an unknown quantity at this point
That explains it. Learned something new today.
Calver is offline   Reply With Quote
Old 09-23-2020, 10:43 PM   #14
Kingtal0n
Kingtal0n's Avatar
this is a picture of stock restrictor for sr20
https://zilvia.net/f/showpost.php?p=...0&postcount=19
however the size of restrictor depends on the flow rate of the pcv system, suction from the intake manifold and size of orifice of pcv valve.
SO if you've modified the intake, the engine, the pcv valve, anything between the intake manifold vacuum signal, the intake port, the pcv system, then the size of the restrictor will need to be adjusted to return the crankcase resting pressure to the correct range of 1-3" Hg,
Anything over 3" Hg can damage the oil pump and ruin the engine seals (engine rebuild)
so err on the large side if in doubt
Old 09-28-2020, 12:31 PM   #15
d1zguy2
Thank you for all the OG info and saved me lots of time and headaches! Replace the forward section, salvaged the restrictor from OEM hose heated up and inserted it into homedepot vynil water hose, fitted a close catchcan.
The restrict or was actually in the hose itself, the boot barb was just a fitting to allow it to take a hose into the stock rubber boot.
