Old 02-02-2018, 11:42 AM   #1
NoFlex
NoFlex is an unknown quantity at this point
Replacing Heim Joints/Rod Ends RUCA
So my Rear upper control arms have play (ISR V1 ARMS S13) in the heim joints/ rod ends. I want to replace just the rod end and not the whole control arm!!
I measured the size of the rod end and it is M14X2.0X45mm
The opening for the rod bore (for the bolt to go through) without the two washer things installed is 17mm.
For some reason all the replacement rod ends I am finding have a 14mm bore?
Has anyone ever replaced these before?
Link of the replacements I found:
http://www.midwestcontrol.com/part.php?id=3002
NoFlex is offline   Reply With Quote
Old 02-02-2018, 11:46 AM   #2
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
I was doing the same thing lately. It's almost impossible to find the one you need. I found one for my application in the UK and it would cost me like $25 for a heim. Almost makes more sense to just buy a new set at that point. The only cheap heims you will find are the ones they use on american roundy round cars.
I found this but I don't know if I would trust it: https://www.ebay.com/i/262873119859?chn=ps
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 02-02-2018, 12:02 PM   #3
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
have you tried reaching out to ISR to see if they can get you spares? I tried to do this years ago with an arm on another car/chassis and the biggest issue I ran into was the fact that everything was standard/fractional size/thread. I used to have a 200+ catalog with all heim stuff too, but I cant seem to find it. ill look again later and see if I can get the name of the company. so far all ive seen via a quick google is FK and RBC.
jumpman2334 is offline   Reply With Quote
Old 02-02-2018, 12:06 PM   #4
NoFlex
It is very difficult to find! The one you linked me would work for the thread size but the bore size is 14mm and mine measures about 17 or 18mm
Old 02-02-2018, 12:16 PM   #5
NoFlex
I tried to contact them on fb/ig but no reply yet. I'd appreciate if you could find it!
Old 02-02-2018, 12:41 PM   #6
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
hey you go guys
never impossible to find anything
https://www.mcmaster.com/#rod-ends/=1becep4
look for the right load rating prices depends on what its for
let me know if you need more info
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 02-02-2018, 12:57 PM   #7
NoFlex
Originally Posted by s13silvia123 View Post
hey you go guys
I have looked on there already, they did not have what I needed in terms of size. Also the only m14x2.0 was over $50 each
Old 02-02-2018, 01:17 PM   #8
s13silvia123
http://www.aurorabearing.com/index.html
http://www.fkrodends.com/
https://www.qa1.net/rod-ends-and-related/rod-ends
http://www.skf.com/us/index.html
this too
Old 02-02-2018, 05:40 PM   #9
Mitsubayati
Trader Rating: (18)
^ Same deal. Either too expensive (might as well buy new arms) or they don't have the right size.
Old 02-02-2018, 06:34 PM   #10
Def
...that's the main problem with China-spec arms. You're likely to get some oddball, non-standard rod end.
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 02-02-2018, 07:29 PM   #11
NoFlex
I guess that makes sense
Old 02-03-2018, 03:25 PM   #12
s13silvia123
Yeap yeap correcto
Old 02-06-2018, 09:22 AM   #13
!Zar!
!Zar!'s Avatar
You realize the joint is the main reason why some brands arms cost more, right?
Broke-boy arms use dumpster-spec joints.
Old 02-06-2018, 11:28 AM   #14
Mitsubayati
Trader Rating: (18)
I was at OSH last night and to my surprise they had an m14x2 heim joint. I have no clue what the static loading capacity is but maybe look into that.
Old 02-06-2018, 11:54 AM   #15
slider2828
slider2828's Avatar
I have like SPL V1 arms and replace my heims with all Midwest Control stuff.
Relatively affordable and I just get usually the highest rated stuff they have... But like with any solid arm, you just gotta check them after every event.
Its race car life, how it is....
Turn and Burn!
Old 02-06-2018, 01:21 PM   #16
NoFlex
Only thing I don't get is my bore size on the ISR arms is 17mm, the Midwest bore size is 14mm. When I use the two washer inserts inside of it the bore is a 14mm.
So when you buy the Midwest arms are you still using the two washer inserts for the heim joint?
Old 02-06-2018, 01:26 PM   #17
s13silvia123
measure the thickness of the arms and it will tell why its metric at 17mm
Old 02-09-2018, 08:18 AM   #18
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
My friend and I were able to change our old project Nissan rod ends with QA1. They crossed over thread wise. We had to lathe the sleeve collars lenghth down a little but it was a easy swap.
lok is offline   Reply With Quote
Old 02-13-2018, 01:19 PM   #19
NoFlex
So every single replacement rod end I find for M14x2.0 has a 14mm bore. I need a 17mm bore! But I think I will just buy the 14mm bore and use some thick washers to replace the insert piece that goes in the rod ends I have now.
