08-15-2020, 10:25 AM | #23372 |
08-21-2020, 12:27 PM | #23375 |
anyone mount an OE kouki 180sx front bumper using just Autocollect Storm brackets and the fender attachment? What is the bare minimum needed to make them at least look fitted? It seems the oe support brackets are NLA, but the side extension piece is. Does the plastic bumper, new from nissan, come with the studs required to fasten the piece to the fender like a stock zenki/chuki bumper does?
08-21-2020, 03:13 PM | #23376 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
the bumper does not include studs. the autocollect storm fender braces work wonders for replacing the bent and flimsy OE units (i run them personally). the bumper support brackets, not so sure on as of yet. i have them installed on my car, but i am currently running my DorkiDori Type-RH bumper. ill be test fitting my OE 180sx kouki bumper with them when i get around to molding it in the coming months. i dont see why they wouldnt help. but if you utilize the chuki support brackets + OE 180sx kouki fender brackets and upper support brackets, you wont need the autocollect bumper support brackets. |
08-24-2020, 10:03 AM | #23377 | |
08-24-2020, 01:24 PM | #23379 | |
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE! 240 addict miata addict |
08-24-2020, 02:03 PM | #23380 | |
08-24-2020, 04:29 PM | #23381 |
Quick question for those that have replaced your door hinges for S14s. I have some new ones with fresh hardware coming in the mail and wanted to get some opinions from people whom have done this. How did you do it? Is it best to leave the door closed and replace the hinges one be one? Leave the door open and support it from the bottom with a floor jack and a soft rag?
Thanks |
08-24-2020, 04:52 PM | #23382 |
Thanks |
08-26-2020, 12:51 AM | #23386 |
First time painting bare metal
Are primer surfacers and filler primers the same thing?
Im using spraymax epoxy primer but for the polyester primer im not sure if filler primer is same as primer surfacer (first time ever doing paint sorry) Eastwood 2k polyester primer surfacer (Spraymax 3684026 2k polyester filler primer) |
08-26-2020, 02:26 AM | #23387 |
S13 SR20DET Radiator Bracket or alternative
https://ibb.co/vwVV4Pz
Please look at the picture for reference. I?m looking for the radiator bracket, just like in the picture that helps the side mount intake ?cold pipe? stay in place. It?s in the shape of an L, but ?reversed inside down?. I would like to buy this off anyone. Lmk please or maybe alternatives.
S13 SR, S14 KA |
08-29-2020, 09:08 PM | #23389 |
I got front lower control arms for my s13, +35mm ones and i need tie rods
im thinking 06’ maxima inner and z32 outer for tie rods? Anyone can confirm if these work together? Thanks guys |
08-29-2020, 09:11 PM | #23390 |
im thinking 06? maxima inner and z32 outer for tie rods? Anyone can confirm if these work together? Thanks guys |
08-30-2020, 11:48 PM | #23392 |
Got a new turbo that is not water cooled. Can I just plug the water ports, or do I have to run a line between the two? I've got an sr20.
Also, turbonetics recommendes using an turbo inlet filter. I'd think they would have the potential to plug up and starve the turbo. Anyone ise one? I assume the should they be changed/cleaned periodically? Thanks in advance |
08-31-2020, 03:32 PM | #23393 |
Is the turbo ball bearing?
Either or i would run it if the option is there... its not that much work/money todo it.... and the sr20 already has ports for coolant in and out.... i beleve there are premade lines already made for it https://diftech.com/products/top-mou...0det-062-15432 |
08-31-2020, 04:23 PM | #23394 |
I would run the coolant lines for sure if I had the option. However, the turbo does not have coolant ports like many t3t4 turbos. Wondering if I should connect the feed and return ports on the actual motor, or if I can just block them off. I heard on some motors blocking them can cause undue pressure.
09-01-2020, 02:32 PM | #23396 |
How come older/used nardi wheels are going for more than new ones?
Are the newer ones inferior in quality compared to the older ones? Am I missing something here? new: https://www.ebay.com/itm/ITALY-NARDI...gAAOSwRwFfTXbt used: https://www.ebay.com/itm/Vintage-Nar...Condition=3000
http://www.nissanroadracing.com/ |
09-02-2020, 06:03 AM | #23399 |
Looks like a Synapse Engineering.
http://www.synapseengineering.com/ I have one that I never used. Fit and finish is nice, but I can't speak for performance. |
