04-14-2008, 08:11 PM | #1 |
striped a head stud (sr)
i dont know what to do now. i striped it and its bad like it kinda catches but then slides i guess it was half striped befor hand because it was a loose fit but the rest were fine. whtat can i do to get this out?
Email: [email protected] |
04-18-2008, 06:42 AM | #2 |
allen wrech right? got the right size? be sure to use metric bc there so close in sizes, one bolt can be off by a nanometer and wouldnt work right..as far as getting it out if it is the bolt being striped gt a left handed drill bit get it to bite th end of the bolt and as its spining (slowly) pull up with the drill (note left handed drill bit should turn left to drill in)
04-18-2008, 12:49 PM | #3 |
its the right size but im pretty shore it was atleasty half striped if not full striped befor i started on it and its still totaly torqued down so i dono if a drill will help any
04-18-2008, 01:07 PM | #4 | |
if neither of those work, you could JB weld another bolt to the top of it and use it to remove it or go get a set of easy outs from a hardware store. |
