Old 02-06-2014, 12:14 AM   #1
flarfguh
flarfguh is an unknown quantity at this point
SR SR20DET stalling problem
Hello all,
I have a problem with my 14. It idles rough and spits black smoke from the exhaust. I've changed the spark plugs. All the ignition coils spark. I only use high octane for gas. Fuel flow appears to be fine so far. I changed the oil, and it solved the problem temporarily, but it started acting up again about a week later. Turbo spools up, but at about 5k I have to put more gas in it to red line. If anyone can provide me any information on a fix, I'd greatly appreciate it.
Thank you,
TJ
flarfguh is offline   Reply With Quote
Old 02-06-2014, 12:21 AM   #2
Fuego
Fuego is an unknown quantity at this point
Clean your maf, check vac lines, make sure you BOV isn't leaking.
Fuego is offline   Reply With Quote
Old 02-06-2014, 12:33 AM   #3
flarfguh
Smile
I'll check the maf out and see what happens. I know the BOV isn't leaking, and nothing seems to be wrong with the vac lines. Thank you.
Old 02-06-2014, 12:36 AM   #4
Fuego
Slightly unrelated, but why are you going partial throttle to redline?
Old 02-06-2014, 01:03 AM   #5
flarfguh
I'm not too good of a mechanic, but I was trying to see how hard I had to push the gas to get past the stutter so when I posted on here I could get as specific as possible. Plus, sometimes when I let it rev high for a little bit, it starts to act normal again.
Old 02-07-2014, 01:16 PM   #6
cotbu
cotbu's Avatar
What did the plugs say? My guess changing them masked the problem, so here it is leaking injector, vacuum leaks, and mafs maybe. Check ecu for codes. Do some test, remove fuel rail prime pump look for leaks, at the injectors. Always boost leak test. Or buy a 1 million count pack of sparkplugs.
Sent from my Highly Tune Galaxy S3.4!!!
problems, s14, silvia, sr20det, zenki
