Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
11-02-2013, 03:55 AM | #31 |
PBM coil overs arent bad coils i dont really know the specs on them but ive driven in a few cars with them and they ride good and drift fine. theres a really good suspension write up on here about camber caster toe roll center etc.. to start i would just make sure your car is aligned but when you lower your car your stock arm adjustments wont be able to adjust enough to eliminate all the camber created from lowering your car so just do the best u can until u buy aftermarket RUCAS and all your other suspension arms. dont fallow all these clowns with all their camber and hella flush garabage. u want as much tread on the ground in the rear as u can that way your car will catch when u let off and u will be able to transer and get more angle without spinning out so easy. and as far as the engine cooling goes i always change the water pump and thermostat on any new motor or car i buy and bleed the cooling system. look up the write up on how to bleed the ka motors its real simple. and if u have a good working fan your motor should have no problems staying cool with the stock setup, but if u really want to spend the money on a new radiator to be safe more power to you. just make sure most importantly your temp guage works. on my track car i have digital temp, oil pressure, boost, and air fuel ratio guage. u wanna know whats going down so u dont blow your sh*t. you should be fine in your ka as long as your temp guage works properly and maybe get an aftermarket temp guage if your feeling frisky.
best bet is finding a car on craigslist. i always bring a compression checker and check the compression before i purchase any car. i think the compression on ka's is suppose to be around 165 psi. the most important part is that they are all the same or within 5 psi of eachother. and then i look underneath the car and check the frame rails make sure the body isnt all tweaked out and check the radiator support and front end make sure it hasnt been in a wreck. you will see signs of it all tweaked in there if they tried to cover it up. lol even tho i think every 240 ive bought has been in a front end collision or has had the rediator support swapped out. a lot are going to be like that lol. fire the motor up and listen to the motor make sure its not knocking. i always hold it at 2000rpm and listen for knock or timing chain rattle. and remember every 240sx is OBO lol so bargain with that bitch dont let him add on drift tax to the price. keep it around $2000 |
11-02-2013, 07:22 AM | #33 | |
damn Racepar1...thats the nicest thing Ive seen you say on zilvia...you going soft damnit!!!!!??? |
11-02-2013, 12:16 PM | #35 |
I am the old man now and I gave up drifting in the late 90s when the family came along. However, a built drift car to us had a differential, clutch, full bucket seat, shocks/spring upgrade (this was pre coilover proliferation era) and boost-up.
Looking in from he outside it seems like everyone now is trying to start off with a race car and trying to catch up skill-wise. As our skill level grew we improved our car to suit. Needless to say my cars never needed more than basic upgrades to handle the abuses I was able to put them through!
www.gtr-garage.com |
11-02-2013, 12:42 PM | #36 | |
Trader Rating: (106)
Feedback Score: 106 reviews
11-03-2013, 10:20 AM | #37 |
Trader Rating: (130)
Feedback Score: 130 reviews
Exactly! /\/\/\/\ everyone thinks they need a cage and a supercharged LS and a wisefab kit and a 900mm wide body with a BCL wing just to go drifting.
Like that other dude said, clutch, diff, bucket, spring upgrade. Then SEAT TIME |
11-03-2013, 05:28 PM | #38 | |
11-03-2013, 08:58 PM | #39 |
when you find your desired s chassis its a good idea to focus on stiffening up the ride abit. Some 40 dollar front and rear strut tower bars work well.
Then welded diff if you on a budget. BUT... it sucks driving a welded diff at high speeds.... just loud and crappy sounding so if you plan on driving the car not only for daily driving but also drifting from time to time your gonna want to spend some dough on a nice LSD. The typical full exhaust system will help flow alittle better. Obviously aftermarket coils is smart however you wanna get a good name brand set. If you have enough play money you can find a power solution.. Most people go SR, i think the ka is fun. But ultimately its your choice. Typically you wanna gain as much experience you can even with limited hp because you learn how to work the car. More power makes it much more simpler ( in my opinion ) to drift and swing the rear end out.
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
11-04-2013, 05:16 PM | #43 | |
11-04-2013, 09:46 PM | #44 |
yeah i will man..i will definitely get that 240 nxt year by feb or march and its gonna be like 3-4k worth..i honestly just wanna fast forward lol cuz i cant wait i feel like a little kid getting a toy for the first time lol and a baby starting on the car world..
Sent from my iPhone using Tapatalk |
11-13-2013, 08:52 AM | #46 |
DAMN. I been ROLLIN readin this thread. Some of you are extremely Sarcastic asswipes. Anyways, this poor kid is a beginner, at least hes askin questions.
Honestly, drifting is a skill, like any skill, it is developed through practice. To successfully develop your skills, buy a car that is already modded with at least Coils, welded diff, alum radiator, Good Fans, 5 speed, intake and full exhaust. This will be the least of what you will need to drift. KA's Really Suck, If you can find an SR20 swapped car youll have a huge headstart. I started Drifting in a built car, So i truly believe my learning curve was much smaller and faster than most who start KA stock cars. Save up your $5k and buy a semi-built car. I have Scored built 240s for 4-6k three times now, So i dont believe its Hard to do. Sent from my SGH-T989 using Tapatalk 2 |
11-13-2013, 09:15 AM | #47 |
Trader Rating: (32)
Feedback Score: 32 reviews
Keep it simple. Stick with a stock KA and spend your money on suspension components.
Get your car set up to drift before you spend a bunch on go fast parts.
Instagram @hiighboost @iasperformance |
11-13-2013, 10:14 AM | #48 |
11-13-2013, 06:43 PM | #49 |
11-14-2013, 11:51 AM | #51 |
Sage advice...
I drive an RB swapped s13, fully built suspension, all out, 300 whp rocket sled. I was in Iraq in 03-04 and read in one of those import mags about the swap, and decided to do it. Once it was done I started hitting events with my awesome machine and proceeded to get mopped up by guys with near stock rx-8s and s-chassis cars making half the power and way less suspension.
My point is this: I was in love with the car/motor swap. not with the skills and practice associated with actually being a good driver. Since then my mindset has shifted significantly and I am pretty decent now. If I could do it all over again, I'd have not swapped, and blew all that money on a legit racing school and track time. When I look at your parts list, I fear you may fall into the same trap. Don't fall in love with the concept of being a drift racer. If you have a very limited budget, then why enkei rims? understand? I bought some sweet 17x10 5ziegens and can barely afford tires, and I have a professional career. so I went to the junkyard and found some q45 mesh wheels for 100 bucks, and they're 15s so tires are cheap. and i'll drift till the tires blow up and i don't mind. Actually become a good driver. go to events. talk to people while you save money. go to road atlanta and volunteer to be a flagger at some scca/nasa events. talk to drivers. talk to DRIFT drivers. do ride alongs. go to Auto-x. you can auto-x with an 87 Hyundai as long as it doesnt leak too bad. it will teach you the fundamentals of driving. find a mentor. Not trying to kill your dreams, just keep you grounded. Best of luck! |
11-14-2013, 02:05 PM | #52 |
Buy the car as cheap as possible
But don't buy cheap parts Buy used expensive stuff instead of new cheap stuff.
Drives a BRZ and is building a V6 S12 coupe. |
11-14-2013, 06:02 PM | #53 | |
yeah i reallly do need a mentor cuz most of my friends here dont know much about cars.. tnx 4 the service bro..it must have been tough out there in iraq..buddy of mine was deployed there too.. Sent from my iPhone using Tapatalk |
11-14-2013, 06:02 PM | #54 | |
11-14-2013, 07:22 PM | #55 |
craigs!
craigslist is the way to go thats how i got my baby for cheap and negotiated with dude he was selling it because it needed a litttle body work re du fender roll cause he messed up and the spark plug wasnt gapped right and didnt know the problem lol but ive been driving it since may no problems!
11-14-2013, 07:34 PM | #56 | |
11-14-2013, 07:36 PM | #57 |
Honestly i would go for a stock as possible just because you don't know exactly what they did when they put it on and what bot you know what i mean but stock is very hard to find! Lol
11-14-2013, 07:39 PM | #58 | |
11-14-2013, 07:52 PM | #60 |
