Old 05-27-2021, 09:33 PM   #1
[email protected]
kronserken@yahoo.com is an unknown quantity at this point
Kouki S14
1995 Nissan 240sx Kouki slick top no sunroof
Original BP3 paint code on chassis clean title. 138k miles, engine has a fresh build on break in tune. Everything works ice cold AC, heat and Bluetooth radio.
Brakes/Wheels-
Z32 front and rear full swap with 5 lug conversion extended studs
R32 rear e brake, working e brake.
ESR 18x9.5+22 front 18x10.5+22 rear.
Suspension-
BC extreme low 12/14k spring rates
Megan upper arm
Megan toe arm
Megan camber arm
OEM ball joint
Engine-
S13 sr20det built motor
Garrett GT2871r
Tomei fuel pump and rail
Nismo 550cc injector
CP pistons
BC valve spring
Tomei head gasket
ARP studs
OEM oil pump
Cons- Holes in trunk from previous Wing, has hot start issue needs final tune to adjust start fuel map.
Asking SOLD . Car is located in Dallas TX
https://imgur.com/gallery/EGmheSS
kronserken@yahoo.com is offline   Reply With Quote
Old 05-30-2021, 12:25 AM   #2
inferno s14
inferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-known
the car looks sick my brother good luck
inferno s14 is offline   Reply With Quote
Old 06-02-2021, 01:47 PM   #3
Kirbyz
Kirbyz is an unknown quantity at this point
12k cash? Located Omaha ne
Kirbyz is offline   Reply With Quote
