Old 04-06-2011, 11:23 PM   #1
WINTERS14
WINTERS14 is an unknown quantity at this point
Talking OBDII S14 vs. OBDI S13 Engine/Tranny
Hi,
I'm buying an S14 Kouki (OBDII) shell this weekend, and I'm also hoping to buy a motor/trans (OBDI) from an S13 with 112K on them to put in the kouki. I've done some research and apparently the only difference in the motor is the distributor and the upper intake manifold (Kouki is OBDII and has extra sensors on the manifold). However, I'm not sure if the transmissions are the same as well, or if there is something different. Like I said the motor will be OBDII compliant without too much hassle, but what about the transmission? Thanks for your help guys!
WINTERS14 is offline   Reply With Quote
Old 04-06-2011, 11:38 PM   #2
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
The transmissions are almost identical (assuming they are DOHC), with the exception of a 1/2" hole in the top of the bellhousing on S14 transmissions to accomodate the crank angle sensor, and the dust cover on the yoke being metal on S13s/rubber on S14 trannies.
omgRWDgoodness! is offline   Reply With Quote
Old 04-06-2011, 11:59 PM   #3
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
Don't forget about the speed sensor.
instagram
1on1 is offline   Reply With Quote
obd1, obd2, s13, s14, swap
