07-04-2013, 07:38 PM | #1 |
Garage Cleanout CA18/SR20/KA24 !!!!
Time to clean up the garage and save up for drift events!
Willing to ship at buyer's expense. Located in Huntsville, Alabama. I accept PayPal and WesternUnion! Miscellaneous Parts: Nismo Type-A adjustable fuel pressure regulator (SR/KA/RB/CA) $100 T25/T28 compressor outlet with 90 degree coupler $25 T28 oil drain $20 T28 Adjustable wastegate actuator with bracket $25 s13 motor mount $20 Greddy BOV flange (weld-on aluminum) $5 Greddy BOV flange (clamp style) $5 pipe with flange for HKS ssqv bov $10 Blitz turbo timer scratched up $20 s13 rear calipers $25 s14 water temp sensor (for gauge) $10 z32 MAF pigtail $10 t28 elbow o2 housing dump gasket $5 CA18DET Parts: Intake cam $20 obo Cam gear $5 Starter $30 Timing belt idler $5 (2) Throttle Position Sensors TPS $20 each obo (2) Ignitor chips $20 each (2) Cold-Start valves (aka Air regulators) $15 each Idle control valve (aka IACV, AAC) $20 Air conditioning idle-up valves $5 Power steering pump $25 Oil pressure sensor (aka sending unit) $10 (2) sets of coil packs with harnesses **SOLD** KA24DE Parts: Starter $30 Accel performance coil $20 Oil pressure sensor (aka sending unit) $10 Idle Air Control Valve (IACV, AAC) with subharness $25 ECU $25 SR20DET Parts Water neck $20 Turbo hard lines (all 3) $25 Oil pressure sensor (aka sending unit) $20 ALL PARTS SOLD AS IS
07-07-2013, 04:31 PM | #3 |
Nismo FPR and one CA18 ignitor chip sold!
Turbo compressor outlet, SR20 turbo lines, T28 oil drain, and adjustable wastegate actuator sale pending!
09-09-2013, 07:49 PM | #5 |
Trader Rating: (53)
Feedback Score: 53 reviews
T28 Adjustable wastegate actuator with bracket*$25
$25 shipped to concord nc 28025..... do you have the other end for it and the nut? [email protected] |
10-18-2013, 05:10 PM | #9 |
Trader Rating: (53)
$25 shipped to concord nc 28025..... do you have the other end for it and the nut? [email protected] T28 Adjustable wastegate actuator with bracket*$25 $25 shipped to concord nc 28025..... do you have the other end for it and the nut? [email protected] |
adjustable wastegate, ca18det coilpacks, iacv, nismo fpr |
