10-31-2022, 08:34 PM | #1 |
S13 SR Turbo upgrades.
Recently my turbo went out (oil seal gone) turbo smoking like a coal train.
About to upgrade but on the fence wanted a 2nd/3rd opinion before i make a decision. Want to keep it simple but not opposed to changes. Currently running stock turbo mani (the heatshield is nice and stock mani is stout) however ISR mani's look and sound good, with the ISR V2/V3 are you able to run the stock oil catch can/collector or does it absolutely have to go? aside from that IF it does have to go has anyone run the radium S13 oil catch can setup? it looks good. Been looking for a S14 V.Cover to do the 13.4 but with prices today it's like spending 1k just to get a proper catch can setup. So the radium stuff seems to make sense. 2871/2863 (garrett turbo) is what im looking at OR a 3071 top mount looks good but trying to keep it more responsive. Any suggestions would be appreciated. Saving up a check or two then want to buy it all at once. lmk what you guys run P.S. - SR has been rebuilt, maybe 9-10k miles on it since rebuild, Entalpy tune, 750cc injectors, tomei poncams so not entirely stock but not crazy built either
If I had a dollar for every pet named "nismo" by a nissan owner Id be rich Last edited by doridoridori; 11-01-2022 at 06:33 PM.. |
11-01-2022, 09:50 AM | #2 |
if you want a simple bolt on turbo I suggest this.
https://mmpturbos.com/blogs/news/wel...e-family-ns400. If you want something nicer with better tech you can always go g25-550, or efr 6758. Both options are considerably more expensive.
Need aftermarket parts? PM or DM me competitive pricing! IG@S13Guille |
11-01-2022, 06:25 PM | #3 | |
A friend of mine runs one and says it's pretty solid! just not sure i feel like waiting for shipping from AUS, G25-550 is NICE but is it splitting hairs money wise compared to getting a 2871r or even 2863?
If I had a dollar for every pet named "nismo" by a nissan owner Id be rich |
11-01-2022, 10:07 AM | #4 |
Trader Rating: (130)
Feedback Score: 130 reviews
garrett gbc 22-350
roughly same cost as a new s15 turbo, but current day design. bolts up to stock manifold, but will need to be clocked so the oil drain points straight down, and the outlet points in the right direction. Will need a oil drain tube made. I took a s14/15 t28 drain and chopped / welded it to fit perfectly. imo its a great value for the price, and plenty of puff for street cars. |
11-01-2022, 06:30 PM | #5 | |
11-01-2022, 12:27 PM | #6 |
GTX2863 would be a nice bolt-on upgrade.
11-01-2022, 06:31 PM | #7 |
it does seem pretty promising and newer tech compared to a 2871 from what i was told, im not sure how old/new the 63 is but seems good. Via ATP says capable of 450hp
11-01-2022, 01:14 PM | #8 |
I run a GTX2860 with an xspower manifold and my car screams. 420 whp on 18 psi (granted that's with e85, cams, and 10.5:1 comp), but it would be my choice for any power goals 370 ish whp and below on a stock setup.
11-01-2022, 02:55 PM | #9 |
I run a GTX2863 w/ .64 AR hotside, stock mani/engine, nismotronic w/ 740cc right around 20psi. It has a great midrange pull, but I think the .64 is choking it out a little on the top end. 'Tuned' by me, no dyno.
It's plenty for me with a stock engine and S13 as a daily, but I do wonder how a GTX2867 with a larger AR hotside would have done. Probably pretty wild with some cams, but I'm not sure a stock SR20 would handle that. 2867 is also +$500 vs. the 2863.
S13 |
11-01-2022, 06:36 PM | #10 | |
I called ATP they said the 2863 is newer tech compared to the 71 or 67. does the 64 feel restricted ? Granted i want more lower/mid range anyway so i think a .64 should be fine.
11-02-2022, 09:21 AM | #11 | |
A GTX2867 with some cams would rip, but I'm not sure a stock SR20 on pump fuel would like it though.. Maybe someone else can chime in about .64 vs .86 A/R.
S13 |
11-02-2022, 10:32 AM | #12 | |
The 64 spooks and creates good useable torque around 3400 to 3500 RPM. The .86 doesn't do much still 4200 ish.... But then gain horsepower at the top and peak torque at the top for longer. Granted this is a built motor bottom and top. .86 was like 380whp on a dynodynamics which is similar to a low reading mustang dyno. It just depends how you drive and what you like to do. I don't drive much on the street cause its Cali and cops pull you over for no reason other than an exhaust so yeah..... I stay to the track and ring it to 7500 rpm.... Else I .64 is plenty.
Turn and Burn! |
11-01-2022, 06:09 PM | #13 |
You absolutely cannot beat the GTX2860 Gen II if you're looking for a direct bolt on turbo that needs the absolute minimum amount of modifications.
Value for dollar will go to the GBC22-350, but more modifications are needed as detailed in brndck's post. Personally I'm a fan of the EFR line. The response is insane. Don't waste your time with an aftermarket bottom mount manifold. If I was going to buy a new manifold again, I'd go top mount, even if I wanted to run a T25-flanged turbo. You can modify your stock valvecover to work perfectly fine with a normal catch can setup, see this thread: https://zilvia.net/f/showthread.php?t=235851
11-01-2022, 06:39 PM | #14 | |
11-02-2022, 08:52 AM | #15 | |
Juicy slayin aint easy, but dammit somebody has to do it!!! |
11-03-2022, 06:59 AM | #16 |
Bigger turbine housings on old garretts are dumb. All it does it shift your powercurve right and doesn't net you much more top end. Just buy a better turbo and you won't have to make that compromise.
GTX2860 Gen II on built SR at 23psi on 100octane. If you want a 300-400whp responsive setup, it's either this or a 6258/6758 IMO.
12-14-2022, 11:57 AM | #17 |
appreciate the help/feedback. Made my mind up, going top mount G25-550, figured i'd treat myself to a really nice setup for once haha.
Top mount G25-550 EWG (38mm) etc. i'll report back and let people know how it is if anyone wants to know. selling the stock bottom mount mani/heat shield and a few other things.
12-14-2022, 01:22 PM | #18 |
I made over 400rwhp dynojet gt2871 T25 flanged 86a/r with a perfectly flat torque curve on a built sr20 back in the day...
... at like 15:1 air fuel ratio. Because I was an idiot in a rush that day like a decade ago. Running lean off the charts it still made perfect torque and peaked out higher than I thought possible. It should make over 420rwhp with the fuel in it. I still have it just sitting.... sigh |
12-15-2022, 09:56 AM | #19 | |
2871 is ol' reliable, great turbo for sure
12-14-2022, 03:27 PM | #20 | |
UMKAYSO, please see my comments on this topic here:
(also OP, congrats on the g25-550, but what top mount manifold are you using that comes in t25?) Quote:
12-17-2022, 08:33 AM | #22 |
that's basically what i had that went out, was nice while it lasted haha.
oil seals were toast.
12-17-2022, 02:49 AM | #23 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
i have a brand new universal GT2860 in box that i need to get rid of... will do around 350hp if youre interested. will require some ingenuity to have installed, but is a great upgrade from an S15 turbo.
12-17-2022, 09:22 AM | #24 |
kinda set on the G25 but what flange and price?
12-18-2022, 12:47 AM | #25 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
i bought it for $1300... want it gone. $900 shipped sound fair? i literally took it out of the box for 2 photos and put it back in the box. has been sitting in my storage room here at home ever since. and its a .84 trim i believe. GT25 series is actually smaller than S15 turbo.
12-18-2022, 08:21 PM | #26 | |
the manifold im having made is already Vband for turbo and EWG so this won't work unfortuately but i appreciate it!
