10-07-2020, 05:31 PM | #1 |
Will a a340e fit in a s13?
Can anyone tell me if a a340e automatic out of a Toyota Supra will fit into a s13 I have looked all over Google and other sources and nothing other then someone is using it in a s14 and going 7s. But that doesn't tell me if the chassis had to be modified cut or bashed to get it to fit. Need my car mobile in the next few months and these are basically free and I already have a transmission controller that is just sitting. I'm going manual in the future but for now just need it to drive.
10-07-2020, 06:38 PM | #3 |
i've ran an a340e in an s13 for 10+ years. fits good, one thing i wish i would have done is massaged the area by the starter so i can change the starter easier. otherwise nothing needs to be done other than a crossmember.
10-07-2020, 07:06 PM | #5 |
Also do you have any other tips for installing it? What are you using to controll the trans ? I have a trans controller called a smart 100.1 from forcedfour that can totally replace the factory TCU
10-07-2020, 08:19 PM | #6 |
I have only used J3 bell housings. i have an extra i'd sell cheap if you're in need.
I used the stock ecu with a mapecu2 for a while, then an AEM EMS V2 and now i'm on a pro-efi 128 setup. I'm not familiar with the smart unit for controlling the trans. If memory serves me right i used the tech2 crossmember with the auto supra mount. i'll have to see if i have any pictures of it.
10-07-2020, 08:25 PM | #7 | |
