Old 01-21-2010, 05:25 PM   #1
otto_3478s
otto_3478s is an unknown quantity at this point
1990 S13 Hatch -- Neukin Caged/ S14 KA/Trans/Centerforce/Megan/5-lug/Welded diff...
ASKING PRICE --- ONLY $2800!!!!
-The car is on stock suspension
-NA with stock header and radiator
-Runs good and its loud
-Stock seats
-Neukin Tig Welded Roll cage with 1.75 DOM tube .120 THE SAFEST out there - $1800 Alone!
-Custom cut gussets on drivers side tie cage into chassis for a ridged setup.. perfect for accurate tuning of suspension
-Padding for impact safety and if you drive on street with no helmet
-Muteki blk open wheel lugs and key
-ARP extended studs
-5lug swap with new rotors and hawk pads
-Walbro 255 fuel pump
-hood with louver for vmount
-Keys for both doors, not used for starting though, just switches as a lock bolt in wheel is illegal for TTU race class
-Clear title and steetable (Have driven to a few events and taken the highway for 2hr just to get there)
-Odyssey PC680 battery (11 pounds!)
-6 switch bank (Used right now: Fuel Pump, Fan 1, Fan 2)
-Two main switches near cluster (Ignition and start)
-THE LACK OF RUST IS GREAT!! Not just fixed, it really has no major rust on chassis or frame rails like you typically see on S13's
-Has some small dents and such, i was never worried about looks since its a racecar. Would be easy to clean her up and put a kit or paint on.
-New slave and master for the clutch
-New hardline and stainless flex line.
-Megan Front Roll Center Adjuster ball joints - (after you lower car these help flatten the lower control arms so Nissan designed suspension goes closer to intended geometry)
-Megan front steering S13 Rack Ends add more steering angle -
-Megan Tie Rod Ends -
-Megan Front Pillow Tension Rods -
-Megan Rear Lower Toe Arms -
-Megan Rear Lower Traction Rods -
-Megan Rear Upper Control Arms -
-Russell stainless brake lines -
-Welded Neukin Diff
-Steel one piece drive shaft -
-OBD2 96 higher power S14 motor/ecu/trans This ecu enables the ability to run Nistune!
-Custom Wire harness from Nissan Wire Specialist
-Brand new alternator
-Neukin stainless Oil feed and stainless oil drain for turbo
-System ready for turbo
-Sparco hood pins/latch system from Italy
-Neukin power steering relocation keeps the pump cooler and better inlet for turbo S14 KA -
-3" aluminum race exhaust downpipe back with custom mounts and hangers -
-NRG short hub, quick release wheel 2.5 and "Race" leather wheel w red stitch -
-One set of SportMax 17x8 with pretty worn Fuzion ZRI -
-10mm wheel spacers on all 4 corners -
-Aftermarket Top feed fuel rail with honda fuel pressure regulator -
-Fuel pressure gauge on rail
-S14 cluster and wires that need installed -
Thats all I can think of for now.... Will update with new pics soon!!! Thanks for looking!!!
otto_3478s is offline
Old 01-24-2010, 11:34 AM   #2
otto_3478s
Bump bump bumpy!
Old 01-24-2010, 04:03 PM   #3
rioredstang
rioredstang's Avatar
rioredstang is an unknown quantity at this point
I have a 93 s13, will ecu work in it? If so how much?
rioredstang is offline
Old 01-26-2010, 11:47 PM   #4
neukin
neukin's Avatar
neukin is just really niceneukin is just really niceneukin is just really niceneukin is just really niceneukin is just really niceneukin is just really niceneukin is just really niceneukin is just really nice
Send a message via AIM to neukin
We need this chassis outa here, someone pick her up and put it to WORK
Neukin Motor Development llc 399 River Bend CT Fort Wayne IN 46803
-->Neukin Store<-- -->DRIFT Clutch Store<--
neukin is offline
Old 01-27-2010, 02:21 PM   #5
otto_3478s
Its not a part out, and no that ecu would not work in your vehicle.
Old 01-27-2010, 06:06 PM   #6
shortyman4065
shortyman4065 is an unknown quantity at this point
How's the rust? the underbody seems to be decently clean...how many miles on the engine? LMK, thanks.
shortyman4065 is offline
Old 02-04-2010, 10:27 AM   #7
neukin
neukin's Avatar
GA car, NO rust on chassis... there was a 1x2 area of rust on the rear window hatch you pop... inside the car oddly. i can send you a picture just PM me your email if it worries you. THe rest of the car is clean clean clean!!
The MOTOR/TRANS/ECU is a S14 setup.. not sure on miles but when the guy did his SR swap i think it was close to 60-70k miles on the setup. Motor runs so well, not a problem.
neukin is offline
Old 02-20-2010, 01:26 PM   #8
shmokey35
shmokey35's Avatar
shmokey35 is a well-known jackass
Send a message via AIM to shmokey35
this still for sale bro?
shmokey35 is offline
Old 02-20-2010, 01:30 PM   #9
shmokey35
shmokey35's Avatar
pm me if you get a chance. i know this is a bit old
Old 03-19-2010, 02:12 PM   #10
neukin
neukin's Avatar
Yes still have it!!!! BUY IT NOW!!!!!!!!!
neukin is offline
Old 03-19-2010, 09:58 PM   #11
xBlastoisex
xBlastoisex's Avatar
xBlastoisex is an unknown quantity at this point
Very well built car.. GLWS
xBlastoisex is offline
Old 04-05-2010, 08:16 AM   #12
android05
android05 is an unknown quantity at this point
interested.. pretty cool setup u have. would like to talk about more details if you still have this lmk
android05 is offline
Old 04-22-2010, 09:37 AM   #13
neukin
neukin's Avatar
Sold sold sold
neukin is offline
5lug, cage, drift, ka24de, s13
