Old 07-09-2019, 07:45 AM   #1
Sil_Eighty88
Sil_Eighty88 is making his/her stupidity well-knownSil_Eighty88 is making his/her stupidity well-knownSil_Eighty88 is making his/her stupidity well-knownSil_Eighty88 is making his/her stupidity well-known
Ca18det motor issue
So when I first bought this car a couple weeks ago it seemed fine, but after about a couple days later i started to noticed it hesitate a little bit under power(just for a split second). Now it has progressively got a lot worse, when idling it bogs down almost to 0 and almost just dies, then goes back up to a normal idle then back down. If I try to put it under power when it does that it has no power and just sputters. I dont know what the issue is. I just put new spark plugs and a new intake on it. Please help!!
Sil_Eighty88 is offline   Reply With Quote
Old 07-09-2019, 07:49 AM   #2
Sil_Eighty88
I have a quick clip of it but it won't let me upload it.
Old 07-09-2019, 07:51 AM   #3
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
could be a number o fthings... most likely a pre-turbo boost leak.
Old 07-09-2019, 07:53 AM   #4
Sil_Eighty88
Would a boost leak really effect the way it idles though at a dead stop?!
Old 07-09-2019, 08:06 AM   #5
Sil_Eighty88
Ca18det motor issue
Old 07-09-2019, 08:14 AM   #6
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
dying fuel pump, vacuum leak, boost leak, tons of stuff you need to check before you can get a decent answer from us.
with such vague information, we can only provide vague advice.
go check the basics.
FAST
Fuel
Air
Spark
Timing
Old 07-09-2019, 11:21 AM   #7
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
wow. someone went this engine route...what a doop.
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 07-09-2019, 12:04 PM   #8
Jamaica
Jamaica's Avatar
Jamaica is an unknown quantity at this point
Have you checked for boost leaks?
Jamaica is offline   Reply With Quote
Old 07-09-2019, 12:27 PM   #9
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
as brndck just stated... there are A LOT of potential things that could cause your problem. i just pointed out on that has caused problems kind of like what youre describing on my SR.
bogging is usually either a fuel, ignition or boost leak related issue. clean your MAF, make sure all the connectors inside the MAF are making a connection. are all of your clamps on your IC piping tight? if youre using worm gear style clamps, how many times have you torqued them... if more than 2-3, they need to be replaced. have you pulled your coilpack plugs 1 by 1 to make sure youre not running into weak spark or ignition in the cylinders? you mentioned adding a new intake, did you make damn sure your clamps are 100% tight before the turbo and its not pulling unmetered air behind the MAF? do you have an in cabin fuel pressure gauge so you can watch your fuel pressure as you drive? do you have an aftermarket fuel pressure regulator? if so, is it a cheap ebay knock off unit or an actual brand name?
see where im going here? there are A LOT of elements to consider in this type of problem.
Old 07-09-2019, 12:51 PM   #10
jedi03
+1 coupler probably off/split
Old 07-09-2019, 05:23 PM   #11
Sil_Eighty88
I will look into all of this. Thanks guys!
Old 07-09-2019, 05:24 PM   #12
Sil_Eighty88
I will look into that ty!!
Old 07-09-2019, 05:54 PM   #13
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Merged threads. Don't make multiple threads in different sections for the same issue.
