09-04-2008, 11:52 AM | #1 |
ka-t idle issue.. died on me today
so my car was driving fine a few days ago until it overheated... it was no big deal, the coolant line was resting on the manifold making all the passing coolant super hot.
so when i fixed that i tucked those wires between the 2 plugs on the distributor, so all i did was unplug the top plug then plug it back it. i unplugged the maf and plugged it back in after rerouting the wires for it. ever since i did that my car has been driving very weird, as if i have a boost leak. pegs 10.0 AFR the second i enter positive manifold pressure. justin checked out my CELS and i had one for a secondary o2 sensor... mine is screwed into the framerail, where it has been the last 3 months. cleared the code, and it came back on within 5 miles of driving.. heres the BIG issue going into neutral approaching a stop sign/light the idle drops and fluctuates and was nearly dying, shooting to 1k, dying, shooting to 1k, then as i came to a stop settling at 800 where is used to sit. today it actually died, which tells me something is wrong... i know patrick said just clean the IACV, but i cant help but wonder why suddenly it just popped out of nowhere? |
09-04-2008, 12:55 PM | #2 |
it has to be the fact you moved the wires.. check for signs of exposed wiring or even a faulty connector.. make sure all the wiring looks good. Then maybe try puting it how it was before temporarly and seeing if the problem goes away?
www.massimopower.com PH: 1(951)402-5386 EM:[email protected] Special Thanks To: www.aeperformance.com www.domospeed.com/blog For Their Continued Support |
