08-07-2008, 08:14 PM | #1 |
dash going out
my gas gauge started it all. a couple days later, the speedo went out, after that the lights. today the blinkers went out... i got 3 different gauge clusters, and the same thing happened on all three. let me know if you konw anything that could be wrong.
08-07-2008, 09:58 PM | #3 |
Do need the Factory Service Manual? Click here. |
08-08-2008, 12:23 PM | #5 |
check fuse panel aka drivers kick panel (located by your clutch pedal)
also might wanna try searching.... it works
SliDE ThAT Bi@TCH Til' the ZiPTiES FALL OFF! |
08-08-2008, 01:17 PM | #6 |
you probably have a bad ground somewhere if it keeps on blowing fuses look around for frayed wires and wires that don't look hooked up etc etc
poop mama... |
08-08-2008, 09:58 PM | #8 |
could it be ground wire??? it is no where close to 0 ohms, so if i re-run all the ground to the intake, and then one from the head to the fire wall, that should make a few things work better right?
