03-07-2015, 10:56 AM | #1 |
500awhp Honda Civic EX sleeper AWD 2.0L sleeved GSR
2000 Honda Civic EX Coupe
5 speed 173k miles 619-971-6726 Text preferred $10,000 FIRM DO NOT CALL ME TO NEGOTIATE PRICE Suspension Tokico white adjustable struts Full energy suspension bushing set Skunk2 camber kits Custom traction bar on heim joints Interior Very good condition with no excessive wear rips or fades Pioneer headunit Tunerview mounted under radio skunk2 shift knob Dynamat in truck as well as Mercedes S class sound deadening material 10 gallon fuel cell with in tank walbro 255LPH fills in stock location and vents outside AEM methanol kit Engine Darton 85mm sleeved block CP 85mm 9:1 pistons OEM Honda brown bearings micropolished and balanced crank Eagle H beam rods Full ARP hardware Black has been line bored, honed, and ready for assembly full rotating assembly balanced by Arce enterprises 85mm Golden Eagle headgasket ported ITR head ITR cams skunk2 valve springs skunk2 retainers supertech valve guides Head was decked hot tanked and assembled by Arce enterprises Skunk2 intake manifold Skunk2 throttle body Moroso oil pan OEM Honda oil and water pumps Skunk2 cam gears All ignition parts replaced with OEM Honda Hondata S300 AEM fuel rail AEM FPR RC750 injectors Turbo Stainless steel top mount manifold Precision 6031 turbo Tial 38mm wastegate Greddy BOV Backdoor intercooler Polished IC piping 3 layer silicone boots and T bolt clamps 3 inch ceramic coated downpipe 3 inch aluminum exhaust all mandrel bent Magnaflow muffler Transmission CRV 5 speed syncrotech built LS 5th gear Syncrotech carbon syncros 1st and 2nd face plated One off Mfactory LSD Stage 4 competition clutch set DSS 3.9 axles larger hubs ARP wheel studs AWD (DO NOT MESSAGE ME ASKING AWD QUESTOINS) CRV transfer case Suzuki samurai driveshafts custom made DSM u joints custom adapter flanges ARB air locker custom carrier bearing CRV rear diff custom CRV/civic rear trailing arms Rolling Fresh polished si wheels Brand new 205-50-15 Dunlop durezza Z2 Motor is brand new all parts were purchased new nothing used and only used best of the best all gaskets seals and hardware are all oem purchased from dealer. On a 1.8L non sleeved block the car produced 488AWHP tuned by Daniel at church automotive the new motor will be well over 550whp . the 2.0L motor has 130 total miles on it final engine break in and tuning will be up to the buyer for their desired fuel and power level. The car runs great as is but will need to be tuned for maximum output, shipping is an option or fly into San Diego, I will pick you up and you can drive the car home anywhere in the US WITH NO ISSUES. .... Car is a daily driver with working ac and heater and is a total sleeper, stock driving feel until you lay into the throttle. I have driven the car multiple times from SD to LA/OC with zero issues and wouldn't hesitate to drive it anywhere worry free. I would entertain trades just please only let them be of same value and quality...... Mainly looking for 03-04 Mercedes Benz E55 any color except black.. Please send cash or trade offers to 619-971-6726 <font color=""Red""> this is not a stain on the carpet, that light spot must be the sun...</font> =draggbody;49523149] [/QUOTE]
NEGATIVE CAMBER SAN DIEGO CHAPTER |
