08-01-2013, 01:33 PM | #14462 | |
Not sure how to answer this one... if you are doing solid 'lifters' like you lead on, you need to measure each shim clearance and order the correct size to match each valve. If you already measured and now are using a different rocker arm, I would recommend re-measuring both shim clearances corresponding to the replaced rocker.
* S14SR22 * 9.0 c/r * GT3071R * |
08-01-2013, 02:23 PM | #14463 | |
08-01-2013, 06:45 PM | #14464 |
Good choice. Not sure on the question though, I don't know how to go about clearancing shims for HLAs.
08-01-2013, 06:48 PM | #14465 |
Yeah maybe when I'm a bit more mechanically inclined/ have the funds I'll take another shot at solid lifters. Thanks
08-01-2013, 10:35 PM | #14466 | ||||
Trader Rating: (58)
Feedback Score: 58 reviews
If your oil light is on and it's ticking, it's shot. Quote:
They are non specific if you are using new or can reshim the head.
08-02-2013, 02:46 AM | #14467 |
Trader Rating: (24)
Feedback Score: 24 reviews
I rented a miller 135 mig with aragon tank. I will be welding a firewall in. What size wire would be best to use and in what setting do you guys usually have it on?
REVIEW |
08-03-2013, 07:02 AM | #14470 | |
ps Aragon is a kid who rides a blue dragon and fights bad wizards
08-03-2013, 10:47 PM | #14472 |
nardi 350mm vs 360mm steering wheels
ok im looking to buya steering wheel for my s14 but im confused on what to buy i love the nardi deep corn 350mm but i seen all the Japanese drift videos they got the 360mm any input would be gladly appreciated
The heep S14 |
08-04-2013, 08:02 AM | #14477 |
Is Grip Royal not an option? Sized right in the middle of all that, less expensive, custom made ability, and Made down south about 3 hours in Memphis, TN
08-04-2013, 08:54 AM | #14478 | |
They are just repainted ebay steering wheels. Read halfway down. http://clubroadster.net/vb_forum/25-...-wheels-4.html |
08-04-2013, 09:33 AM | #14479 | |
The heep S14 |
08-04-2013, 10:48 AM | #14481 | |
The heep S14 |
08-04-2013, 09:59 PM | #14483 |
would anyone know by any chance who makes this steering wheel? or where I might have a chance of finding one? I don't even know what to search for..
08-04-2013, 11:08 PM | #14484 |
08-05-2013, 12:45 AM | #14486 |
08-05-2013, 12:58 AM | #14487 |
Ok so I have a 89 SOHC 240 coupe and need to find out info on the engine relay ? fuse box thats behind the battery on the passenger fender well. Can I just replace the box itself and solder/shrink wrap the wires to a new one or can i just detach this part of the harness itself and keep it moving with a known good? Can't use/don't want to use current box due to cracked/melting(both the box and a few wires not a lot, bout 3-4 of em in that location alone)/getteo jerry-rigging to jump the stater(Clutch interlock relay issue that will be fixed the right way when sourced). Images can be seen here if need be. http://zilvia.net/f/tech-talk/530321...ires-help.html
S13 Coupe <3 |
08-05-2013, 07:03 AM | #14488 | |
Your coil dropped, body kitted, adjustable RUCA, bolt on car isn't really worth all that at the end of the day because just one more bolt on 240sx with a heh heh heh fancy steering wheel. Bottom line, that steering wheel adds jack shit to overall value Reality school's out for the day, get back to work!
08-05-2013, 10:14 AM | #14490 |
Speed/rpm
Guys, quick question I've got an S13 Blacktop sr with a non-working speedometer and I was wondering what the speed/RPM ratio is ..What would be the RPM reading be say I need to be going at 60MPH in 5th gear (highway cruising )
