Old 09-15-2020, 12:43 PM   #31
Sr20probs
Sr20probs's Avatar
Sr20probs is an unknown quantity at this point
I did man still nothing I’ll keep trying to figure out why it’s not spraying fuel while cranking
Sr20probs is offline   Reply With Quote
Old 09-15-2020, 01:18 PM   #32
S14rebuild
Injector pulse comes from a signal from the cas... it tells the ecu when to ground each injector driver, which fires the fuel injector.
Have u checked to see if u have that signal via cranking the engine and using the monitors on the megasquirt software?
Old 09-15-2020, 01:47 PM   #33
Sr20probs
Sr20probs's Avatar
I have not, I definitely will tho sorry this megasquirt thing is all new to me.i appreciate the time to reply with detailed responses.
Old 09-16-2020, 01:03 PM   #34
Sr20probs
Sr20probs's Avatar
I have everything ready to install the CAS, one thing tho on the FRS post is the dots seem to be opposite, like my right dot is lower than the left, every video I?ve seen the lower dot is on the left. Heres a picture of how the Dots are positioned. https://imagizer.imageshack.com/v2/3...923/GwW7Ol.jpg
Old 09-16-2020, 02:23 PM   #35
S14rebuild
Yea, its s diffrent version of cas...i have the same one u do...u got it installed right. Even if it was a tooth off, if u turn it all tje way left or right it will still start.
But were at a point of no injector pulse..... even if u took the cas out, plugged it in..turn the key on and spin the cas by hand, u should hear the injectors fire/click.
Please check for cas signal on megasquit
Old 09-17-2020, 02:05 PM   #36
Sr20probs
Sr20probs's Avatar
With my CAS lined up on the lower dot on the right, is trigger wheel correct? https://imageshack.com/i/poFV22Arj
Old 09-17-2020, 04:16 PM   #37
S14rebuild
Do this.......
Old 09-18-2020, 02:08 PM   #38
Sr20probs
Sr20probs's Avatar
Going to do it now, where can I find it on tinder studio and any tips before?
Old 09-18-2020, 03:59 PM   #39
Sr20probs
Sr20probs's Avatar
Plugged in my CAS I heard some clicking from the injectors for a little bit then it stopped. Unplugged it and Plugged it back in then nothing. I turned my fuel pump on, 43psi, and nothing
Old 09-18-2020, 06:49 PM   #40
S14rebuild
Well, what are u missing? Postive 12volt or ur pulsing ground on the injectors?
Also id recommend tryn another know good cas.
Old 09-19-2020, 11:40 AM   #41
Sr20probs
Sr20probs's Avatar
Okay so where do I go to check the 12v and ground on tuner studio?
Old 09-19-2020, 01:58 PM   #42
Sr20probs
Sr20probs's Avatar
Now I’m getting slight pops with fuel pump on . That’s it tho
Old 09-22-2020, 03:36 AM   #43
Sr20probs
Sr20probs's Avatar
Update. Have fuel from all 4 injectors. Have spark at all 4 plugs. Plugs are covered in fuel. Mechanical timing is correct. CAS is stabbed correctly. When using starter fluid it will backfire out of the intake. Injectors seeem plugged in right. Can’t figure this out. Bad CAS?
Old 10-21-2020, 06:22 PM   #44
metako42
metako42 is an unknown quantity at this point
This is a long shot but did you remove the CAS chopper plate from the CAS? If so, you might have installed the chopper plate backwards like I once did. Soon as I flipped it the thing started.
metako42 is offline   Reply With Quote
