12-12-2008, 05:39 PM | #1 |
s14 KA engine harness converted to s13 HELP!
hey guys i was wondering how to convert the s14 engine harness on to a s13 harness to properly make the headlights work and turn signals along with ignition sot eh key can turn the car on because i just swapped in a ka24de in my 89 s13 and the motor was from a 95 s14 some help? thanks
Last edited by Smoothlikewater; 12-12-2008 at 05:42 PM.. Reason: copy and paste error |
12-12-2008, 05:57 PM | #2 | |
I'll disable the egr emissions stuff and I am going to disable the knock sensor on my ka as well since it's a daily beater and faulty wiring is to blame. bah! I don't even want to think about it, good luck. subscribed. |
12-12-2008, 06:11 PM | #3 |
well the s13 ka24de has a coilpack where as s14 ka24de doesnt have it and the s13 pop head lights vs the s14 non pop up wiring and the ignition...
I've been search no such luck finding it so yeah asking some smart tech guys that maybe have done the before that can help. |
12-12-2008, 06:32 PM | #4 | |
12-12-2008, 06:49 PM | #5 | |
Second, the engine harness has absolutely nothing to do with the headlights or anything else on the chassis. Nothing. That's two completely different harnesses, you can use any KA engine in your chassis and use any harness, the S14 harness will require a lot more rewiring but all your connections will be made solely for EFI power, A/C, and the cluster. S13s make connections to the underhood harness by the battery, S14s to the F3 plug inside. But again, these have nothing to do with anything else, you can remove the entire engine harness completely and everything else in the car will still work fine.
12-12-2008, 07:39 PM | #6 | |
12-12-2008, 11:37 PM | #7 |
I would use nothing but an S13 harness, it's a direct plug in under the hood and a repin of 6-7 wires inside. 30x as easy as an S14 harness.
12-13-2008, 12:02 PM | #8 |
alright thanks a lot for the info ill go do that oh yeah the s14 ka does have the fifth coil wire where as the s13 does but if i run into any problems maybe you can help me out? thanks for the info though helped out a lot
12-15-2008, 01:38 PM | #11 |
In regards to the 6-7 wires that need to be spliced and re wired, what are those wires particularly?
Are they something that would hinder the car from running at all? Or could I put this 91 harness in and get the car going at least for now? |
12-15-2008, 02:31 PM | #12 |
Go find a writeup on doing a DOHC swap into a SOHC chassis. There's several on this site and tons elsewhere online. Read it. All your wiring questions are answered this. This topic is too widely discussed to get rehashing it daily for people who haven't researched it yet.
12-15-2008, 11:26 PM | #13 |
Wow your making this swap more complicated. Get a S13 DOHC engine harness, DOHC ECU, Distributor, and intake manifold /w all sensors. Relocate PS line and color match your dash connectors for sohc and dohc are not same but wire colors are. I just did this swap but mine was a DOHC already so it just a matter of swapping longblock and keeping the rest the same. GL.
12-25-2008, 12:27 AM | #14 |
turn signals wont work if the hazard switch isnt plugged in, and make sure your headlight motor switch is plugged all the way in as well- that fixed the problem on my sohc-dohc swapped 89 coupe
psh why pay someone else when you can do it yourself? |
11-18-2019, 10:06 AM | #16 |
11-18-2019, 10:20 AM | #17 |
Also, use this for better pics of the s13 Chassis connectors
https://www.nicoclub.com/archives/s1...-s13-swap.html |
