Old 05-05-2020, 08:34 AM   #1
nosuitorty
nosuitorty is an unknown quantity at this point
S13 Wheel Noise
When I?m driving it sounds like a sequential gearbox coming from my wheels. You can hear it all the way through 4th gear and on decel without applying brakes. Don?t know if it?s the tire tread or something like the bearing or axle itself. Any idea what it could be?
nosuitorty is offline   Reply With Quote
Old 05-05-2020, 11:42 AM   #2
blkvrtswp
blkvrtswp's Avatar
blkvrtswp is an unknown quantity at this point
Check all driveshaft bolts. I had 2 loose and the noise was so hard to find.
Jack up the back and run the engine in gear to spin the wheels to find the exact place the noise is coming from.
blkvrtswp is offline   Reply With Quote
Old 05-05-2020, 01:34 PM   #3
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
Could be wheel bearings.
When you jack up the car with the wheel still attached, apply pressure at the 3 o clock and 9 o clock position. Then again with 6 and 12 o clock.
If it?s wheel bearings, the wheel will rock in the sideways or upwards motion.
Do you have a z32 ebrake in there or is it a factory ebrake setup?
collegekid is offline   Reply With Quote
Old 05-05-2020, 08:19 PM   #4
nosuitorty
@collegekid I have z32 brakes
Old 05-06-2020, 01:15 PM   #5
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
so if youre driving along at freeway speed, and you put the car in neutral and coast and let the rpm drop to idle, what does the noise do?
