Old 05-26-2012, 07:50 PM   #1
Dorifto Machine
Dorifto Machine's Avatar
Dorifto Machine is a well-known jackass
SR KA P/S Pump on SR20 ... SR Tensioner Needed?
I'm fully aware that the KA power steering pump can be transferred to a SR bracket with the SR Pulley. However during searching and reading threads on swapping a KA pump to SR20 bracket it has not stated if you also need to swap the belt tensioners.
The reason I ask is because the SR20 I have does not have powersteering, so I bought the bracket and pulley form a zilvia member and he did not send the tensioner with it. I have my KA power steering tensioner but it seems only 1 bolt will line up...
Do I need to source for a SR tensioner or can I make the KA powersteering tensioner work?
Thank you for you time, much help is appreciated!
Dorifto Machine is offline   Reply With Quote
Old 05-26-2012, 07:56 PM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
You will need the SR tensioner. As well as high pressure side banjo bolt.
http://zilvia.net/f/tech-talk/302618...witcheroo.html
Old 05-26-2012, 08:06 PM   #3
Dorifto Machine
Good Deal, That is the same conclusion I was guessing.
I have a Braided line with earl adapters instead of a banjo bolt. So I should be fine in that aspect.
Thanks sir for confirming ! I shall give you 1 beverage of your choice when I make it out to the meet @ sonics.
Old 05-27-2012, 06:41 PM   #4
Dorifto Machine
Do you know how many RIBS the SR20 power steering pulley has?
The pulley he sent me has 2 Ribs and looks identical to my KA power steering pulley...
Shouldn't it have 3 ribs or is it in fact only 2 Ribs ? When I look at the crank pulley on the SR20 for power steering it shows 3 ribs on it..
Old 05-28-2012, 09:24 AM   #5
Dorifto Machine
Anyone have a clue?
Old 05-28-2012, 05:21 PM   #6
jr_ss
Depending on the swap you don't need to swap pulleys. However, the SR tensioner is needed.
Old 05-28-2012, 06:26 PM   #7
Dorifto Machine
Right. As far as the tensioner that's on its way now, he found it laying around. But this pulley is identical to my KA so I was curious, if he did it by error or some came that way.
Its a s13 SR20 Blacktop
Old 05-28-2012, 06:32 PM   #8
Grimace
Grimace is an unknown quantity at this point
Send a message via AIM to Grimace
I just checked and my redtop has 3 ribs.
Grimace is offline   Reply With Quote
Old 05-29-2012, 11:10 AM   #9
Dorifto Machine
Thanks Grimace..
So now I have to search for a 3 RIB pulley...
Old 05-29-2012, 05:27 PM   #10
KiLLeR2001
Trader Rating: (46)
3 ribs. If you check your SR crank pulley you will see the 3 rib pulley that matches it.
Old 05-29-2012, 06:22 PM   #11
Dorifto Machine
Affirmative.
Ive got a 3 ribbed pulley on its way.
Confirmed. You need the : SR power steering 3 Rib Pulley , SR Power steering Bracket, SR power steering Tensioner
Old 05-29-2012, 06:40 PM   #12
jr_ss
Yep, 3 ribs... I checked mine as well. However, I never swapped my KA's pulley for the SR's because there is a significant difference in ODs. Obviously, a smaller pulley means more RPMs and well, I don't need a cavitating steering pump.
Old 05-29-2012, 06:46 PM   #13
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
u can run the ka pully on the sr it will work
just put belt to one side of ribs
and s14 na sr20de had 2 ribs on it
i kno cause i put a s14 sr20de balancer on my det and it matched the ka belt i had on there
i did it for 3yrs no problems
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 05-29-2012, 06:49 PM   #14
Dorifto Machine
So JR SS, your running a 3 Rib belt on you 2 rib KA pulley?
To be honest the size of the pulley confused me, the 3 rib powersteering pulley that this guy is sending me looks exactly like the size of my KA pulley only with 3 ribs. But then again when I was looking online at any sr20 p/s pump I could find, I found it had a smaller looking pulley.
Such as the one in that link posted:
Guess I will have to wait until I get this pulley to say 100%
Old 05-29-2012, 07:03 PM   #15
Dorifto Machine
While researching I came across a couple of people who stated the same thing about running the KA pulley on SR, but some didnt have the success of keeping belts (they snapped belts alot) and some said it was offset a little bit or didnt line up properly. Not sure why or how, but I guess anything is possible .
Old 05-29-2012, 07:09 PM   #16
jr_ss
Yes, I was/am running the 3/2 combo. I bought a 3 rib belt and cut one rib off. Ran it like that for 3years without a problem. Car is currently under the knife, but I plan on running it like that again.
Old 06-30-2012, 11:17 PM   #17
Dorifto Machine
So I finally got around to doing the pump and yet another road block.
I purchased a SR20 Bracket, SR20 tensioner bracket and SR20 3-RIB Pulley . Put everything together on the KA Pump and the tensioner bracket is not even close to the black bracket on the pump.
What am I missing? Last thing I could think would be the black bracket on the pump itself, correct?
Old 07-01-2012, 06:06 AM   #18
TheRealSy90
TheRealSy90's Avatar
That bracket on the pump is installed incorrectly.
Such a good signature.
Old 07-01-2012, 08:11 AM   #19
jr_ss
The bracket on the pump needs to be swapped out for the SRs. KA pump, SR bracket, SR tensioner.
Old 07-02-2012, 11:55 AM   #20
Dorifto Machine
Alrighty, sourcing a P/S pump bracket now.
Old 11-20-2012, 04:40 PM   #21
ivankol
ivankol is an unknown quantity at this point
sorry didint read the date.
ivankol is offline   Reply With Quote
Old 08-14-2013, 06:07 AM   #22
BoostTaco
BoostTaco is an unknown quantity at this point
The banjo bolt and pressure line
anndddd bumping an old thread, where in the heck do you get the banjo bolt pressure fitting I mean is there anywhere out there to source that thing besides off of a new sr pump? Any cross referenced part se-r anything. Any help would be greatly appreciated as I have a ps pump with no pressure regulator and I'm a sitting duck!
BoostTaco is offline   Reply With Quote
ka24de, powersteering, sr20, tensioner
