Old 06-07-2021, 09:28 AM   #1
Kingtal0n
Kingtal0n's Avatar
What is up with this CAS sr20det
Its from an S15 but I've never seen one like this before
why does it look like that?
Old 06-07-2021, 09:40 AM   #2
Kingtal0n
Kingtal0n's Avatar
The disc inside is also different than usual
Old 06-07-2021, 10:51 AM   #3
PoorMans180SX
PoorMans180SX's Avatar
That is a distributor for a KA24DE.
Old 06-07-2021, 10:59 AM   #4
Kingtal0n
Kingtal0n's Avatar
LOL thanks man
hilarious... rolling right now.... I've never seen one before
Old 06-07-2021, 11:14 AM   #5
PoorMans180SX
Originally Posted by Kingtal0n View Post
LOL thanks man
Haha for sure. I think that's an S13 one, S14 might be a little different due to the integrated coil, I've never taken one of those apart before.
Old 06-07-2021, 11:42 AM   #6
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
LOL thanks man
NA S14 and S15s came with a distributor as opposed to COP and CAS. The NA distributor setup is very similar to to the USDM SR20 FWD distributor system. Which is also similar to the KA24DEs
Looks like a 360/4 slit (slits of differing width depending on Cyl 1-4) CAS wheel
RalliartRsX is online now   Reply With Quote
Old 06-08-2021, 01:10 PM   #7
Kingtal0n
Kingtal0n's Avatar
the slits in this one are all the same length.... leaving me to think its for distributor, no way to ID the cylinder (spark jumps to nearest terminal)
strangest thing though... i got it from a guy who swears its out of an s15 sr20det. he gave it to me free... no reason to lie....
And another weird thing... how would the computer know when to fire the injectors if the slits are all the same length? It would need some other kind of crank sensor. I should take a closer look at the disc... was there ever an SR or KA engine that uses batch fire injection or has some alternative crank sensor?
Old 06-08-2021, 01:38 PM   #8
RalliartRsX
Trader Rating: (32)
It's definitely a distributor. But yeah, the guy is probably 1/2 right; it's from a S15, just not a DET. A standard DE, sure.
Rotate the wheel some more. This also may be a 360/1 (where 1 slit is larger than all three) which signifies TDC.
ECU really only needs one reference point for TDC, and it just counts the slits for the remaining 3 cylinders.
https://www.diyautotune.com/support/...rt-your-240sx/
Don't think any SR or KA used batch fire (unless the KA24E maybe??)
Old 06-08-2021, 07:00 PM   #9
Kingtal0n
Kingtal0n's Avatar
Well now I'm dying to try it inside a det just to see if the ecu can make sense of it. The guy never owned a sr20de engine; I tuned his s15 silvia a couple times over the years and thats the only engine he ever owned so... I just wonder. If, you know, the ecu could make sense of it, even though its wrong for the engine. Hmmmmm
So weird.
Old 06-08-2021, 08:27 PM   #10
RalliartRsX
Trader Rating: (32)
Not sure. The DET ecu has the coil drivers. The DE ecu does not
Also, if the CAS wheel is different and the optical pickup is different it won't work
P.s DE and DET engines are almost identical external sans the ports for the oil and coolant feed being tapped on the DET as opposed to the DE where they are not. Valve cover is raw/khaki color as opposed to painted on the DET. He may had had a converted DE to DET and not have know...or got it from a random parts stash. Who knows lol
Everything else bolts up. CAS in place of the dizzy. Etc
Old 06-09-2021, 07:09 PM   #11
Kingtal0n
Kingtal0n's Avatar
Well here is what I am wondering and may never know... Many OEM ecu have backup/failsafe for running an engine without camshaft sensors. For example my 4.8/5.3L LS oem ecu can run on a crank-trigger alone without the camshaft sensor, it simply makes a guess when you first try to start and you get a loud backfire "BANG" on first attempt, second try it starts up and runs fine. The crank trigger is priority for determining piston position, the cam sensor is just for quickly identifying whether you are on compressor or exhaust stroke.
So I am wondering if the DET ecu can do the same thing with a CAS like this one. Maybe it can use the one large window to determine piston position forthright and from that point on it can run the engine just fine...
Too bad sr engines are extinct antique priceless legendary artifacts
