Old 08-13-2017, 03:18 PM   #1
oscarsx
oscarsx's Avatar
oscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-known
1991 300zx twin turbo - 5 spd- clean title -
** LOOKING FOR TRADES (TRADE VALUE 8k) S14 ONLY!!!
PICTURES ON MY CL ADD
https://inlandempire.craigslist.org/cto/6262845092.html
Block was bored, honed & assembled by Arlignton Machine in Riverside, CA.
Z Was tuned in April by GREG over @ Specialty Z. Made 414hp (360whp) @ 12PSI
Engine has less than 10k miles, 174,XXX on Chassis.
I have recipts of rebuild & 90% of all parts installed.
Z is only driven on Weekends, not my daily.
Reason for selling: New project.
Name is Oscar, texting is preffered 760-686-455Five
ENGINE:
Wiseco Pistons .020
King racing rods/main
ARP Head Bolt Stud Kit, Chromoly 8740
Nismo 615CC Injectors
AMS crank/water pump pulley
Selin TRUE dual Maf setup (x2 Jpop chargers)
2.5 turbo back exhaust (NO CATS)
Z1 powder coated hard pipes
Z1 Sillicone bypass hoses & clamps
REV9 Side Mount Intercoolers
CXRacing Aluminum radiator
ZSpec Timing covers/coil pack fasterner kit
Upgraded Recirculation valves (BDE GHK)
Replaced most OEM vacuum hoses with sillicone.
Wiring Specialties Ignition Coil Pack Harness Connector
Circuit Sports T25 Turbo Outlet 4-Bolt Downpipe Gaskets
CZP Silicone 300ZX Turbo Recirculation Valve Hose Set
CZP Sillicone Heater core hoses
CZP Silicone PCV Hose Kit
CZP Throttle Body Gasket
CZP Buna-N 300ZX Injector O-Ring and Insulator Complete Set
NEW OEM Gasket/O-ring Kit (head gaskets, Oil pan, front/rear main seals, etc)
NEW OEM Water pump
NEW OEM Timing kit
NEW OEM Accordion pipes
NEW OEM PCV Valves
NEW OEM Turbo compresor couplers
NEW OEM Turbo gaskets (oil return & inlet gaskets)
NEW OEM Balance Tube O-rings & Plenum seals
NEW OEM Fuel Pump
NEW OEM ACC/IAC idle air gasket
NEW OEM Timing Belt covers
NEW OEM Oil pump gasket
NEW OEM Thermostat
NEW OEM VTC Sprins & o-rings
NEW OEM Oil Pickup o-ring
NEW OEM 300ZX Engine Block Freeze Plug
NEW OEM 300ZX Turbo Coolant Hoses
TRANSMISSION
ACT 6 Puck Clutch (New Pilot bushing, throwout bearing)
Megan Racing Short Shifter
CZP Stainless Clutch Line
CZP Solid Bronze Shifter Bushing Set
CZP Upgraded Chromoly Clutch Pivot Ball
CZP Heavy Duty Clutch Fork & Springs Base Kit
NEW OEM Shifter Boot
NEW OEM Shifter Bracket Dust Boot
NEW OEM Upper Shifter Dust Boot
NEW OEM Striker/Striking Rod Rubber Boot
NEW OEM Rear Transmission Output seal
NEW GENERIC slave master/clutch master
Redline MT-90
SUSPENSION & BRAKES
CXRacing Coilovers
Rebuilt calipers
Hawk Pads F&R
Drilled rotors
Stillen GTZ Front Bumper Lip Twin Turbo
Electronics
Specialty Z chipped ECU
300 Degree 3 52mm Gauge Cluster Din Mount
Innovate MTX L1 widebands (X2)
Greedy OLED Boost Controller
CONS:
- Leaky Steering Rack
- Needs new rotors
- NO A/C (bad compressor??) *ALL AC related items are still installed.
- EMISSIONS DELETED
** FEW VIDEOS **
https://youtu.be/fkAxoNDHEH8
https://youtu.be/P9HPQRCa5P0
https://youtu.be/BQVTIVbD2Tc
IG: @ozc2jz
oscarsx is offline   Reply With Quote
Old 08-25-2017, 02:31 AM   #2
GlidinSlidewayz
GlidinSlidewayz is an unknown quantity at this point
Just got a new good paying job! Can't wait til tax season if you still have this! GLWS bump.
GlidinSlidewayz is offline   Reply With Quote
