06-06-2010, 01:04 AM | #1831 |
Yo i got a supper hard question :ghey: need the entire cigarette lighter assembly they sell them in Autozone they have the "universal" set up. Will this work for my s14? Also have been looking for the cable but not sure if its the right one. Can some one tell me how its supposed to look color?
I only log in when I have money |
06-06-2010, 01:25 AM | #1832 | ||
06-06-2010, 02:19 PM | #1833 |
i keep blowing 75a fuses, what should i be looking for in my wiring? im sure my alternator is connected and grounded properly
-Jorge |
06-06-2010, 02:47 PM | #1834 |
Trader Rating: (24)
Feedback Score: 24 reviews
RB20 harness to S13 pics?
i got the write up but the pics are gone already(deleted) i know someone saved it. i really need it to make things easier/faster. pm it to me or email [email protected] |
06-06-2010, 07:02 PM | #1836 |
Small Questions Thread (Use this insted of making NEW threads)
If you have it tuned for that specific amount
Of air flow yes!
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
06-06-2010, 09:27 PM | #1837 |
Would a bad power steering pump cuase hard spots? when i make turns, sometimes the wheel will lock on its own and if i dont turn it back itll just keep turning its kinda scary somtimes
06-07-2010, 04:32 PM | #1838 |
Were can I buy this shift knob, I can't find it. Need help with it plz.
IG: chris___s14 |
06-07-2010, 04:35 PM | #1839 |
The Architect.
Trader Rating: (392)
Feedback Score: 392 reviews
See that name in there?
"fromxtor" You can PM him. Hell, he posted up what brand that shift knob is. Google it. WC Lathe Werks - Home of the customizable, hand-crafted shift knob! - Terms |
06-07-2010, 04:37 PM | #1840 | |
IG: chris___s14 |
06-07-2010, 05:29 PM | #1842 |
allright, here's my question...
Last time I bought some side skirts for my s13 was a about 3 years ago. I bought some AIT ones and the fitment wasnt bad at all... now the old ones are gone and I just purchased some Riceoneusa ones and the fit and finish is just absolutely HIDEOUS. The skirts are super thick (maybe around 1/2" thick), and dont fit around the door area at all. So my question was, are these just a bad set or is this the "quality' Riceonusa has?? |
06-08-2010, 01:23 AM | #1843 |
Quick question.
What are the longterm effects of a bolt missing out of your turbo manifold.. Like, loss of compression in one cylinder maybe? (Or would that just be intake manifold?) perhaps late spool, loss of power? |
06-08-2010, 11:29 AM | #1845 |
^ I still did change out oil every 3K miles...even tho my mechanic said you don't need to for 7K of regular driving with Synthetic. Now that my car is a track car, I pretty much change out my oil every 2 to 3 months with 2 weekends of drifting per month...w/ synthetic. (Over kill? probably)
06-08-2010, 08:05 PM | #1847 | |
put breather filter on valve cover tee, plugged port on intake. car lost some vacuum and idled like shit. took filter off, put hose back on, ran fine. do you have to adjust iacv when you run a breather filter?
06-08-2010, 09:50 PM | #1849 |
Trader Rating: (32)
Feedback Score: 32 reviews
k guys, i got an s14 t28 bb and im guessing my wastage went out. it wont boost over 5 psi but i disconnected the vacuum line making sure i did my pulls in 3rd gear to control boost. the result is 8psi+ and it keeps going. i didnt hit over 9psi cause i dont want to blow my motor so wastage with vacuum=5 psi
wastage without vacuum line = 8ps+ does that mean its a bad wastage? im pretty sure it is. |
06-09-2010, 08:47 AM | #1850 | |
also, what goes in the place of the power window switch for cars w/o power windows? does anyone have one they want to get rid of?
06-09-2010, 10:08 AM | #1851 |
Well when i went to JWT for rom tune they said they just needed to know what maf i was going to use so they could tune my ecu for that amount of air flow so seams like that makes sense.
Correct me if i am wrong, i know even cobra mafs can be used , z32, and others
06-09-2010, 10:11 AM | #1852 |
Skip that whole setup. I hate valve cover breather filters. See it too often with the Honda fanboys. Instead, run a hose from the valve cover to a catch can, and from the catch can to the intake.
06-09-2010, 11:47 AM | #1854 |
Trader Rating: (22)
Feedback Score: 22 reviews
guessing this will be quick question since this is a common problem with 240s
u know when u turn the key and it doesnt start but makes that clicking noise but eventually does start and it isnt the starter doing it? what is it. i have heard maybe ignition switch or not getting a good connection from the pigtail hanging out of the ignition. |
06-09-2010, 12:28 PM | #1855 | |
You can also check this thread out: 1991-1994 240sx Starter not turning engine over tutorial : 240SX Technical Forum |
06-09-2010, 12:32 PM | #1856 | |
Trader Rating: (22)
i had the hole starter rebuilt before and still same problem which is why im looking at other options. ill check out the link though thx |
06-09-2010, 01:19 PM | #1859 |
something i was thinkin of that i havent seen anyone do yet.. i want to build a ka24det stroker motor.. my ?.. is there anything wrong with building a turbo stroker motor?
SPEED KILLS!! Drive a Honda and live forever!! |
06-09-2010, 03:22 PM | #1860 |
I bought the Greddy Baffled Oil Pan for my sr20det RedTop, but it did not include the hardware for installation, the baffles are already installed. What bolts do I need to buy to install this pan? I'm not sure if any of the factory ones will work since the clamping area is thicker than the stock metal pan. Plus there are the four bolts that definitely need to be longer since they go through the middle of the pan. Thanks for the help!
