Old 10-05-2011, 09:14 AM   #1
thesandman6
thesandman6 is an unknown quantity at this point
Strange cas alignment sr
So I been helping a friend put his sr back together after he took it apart to put in arp head studs and a new head gasket. While resetting the timing, the car wouldn't run at all with the cas set per fsm instructions, but runs when the cas is installed roughly 90° ccw from the alignment dot. The cas is brand new also. Anyone ever run into an issue like this before?
thesandman6 is offline   Reply With Quote
Old 10-05-2011, 11:23 AM   #2
Sileighty_85
Sileighty_85's Avatar
Cam Timing is probably wrong
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-06-2011, 06:38 AM   #3
thesandman6
Cam timing is good, 20 rollers between marks, was checked about 10 times, and the motor puts out 150 compression on all cylinders.
Old 10-06-2011, 06:56 AM   #4
vas570sx
vas570sx's Avatar
vas570sx is an unknown quantity at this point
i had a problem like this a long time ago.. i just ran the motor with the timing lookin all weird, but it ran good, so i didn't care. I know this doesnt help, just lettin you know.
vas570sx is offline   Reply With Quote
Old 10-06-2011, 07:30 AM   #5
Seen
Seen is an unknown quantity at this point
A friend of mine had his CAS set just like yours and when we pulled the motor apart we found out the cam timing was off 1 tooth.
Seen is offline   Reply With Quote
Old 10-06-2011, 07:46 AM   #6
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Chain is off, or you weren't at TDC when you set it.
Old 10-06-2011, 08:20 AM   #7
obsolete
obsolete is an unknown quantity at this point
If it was a case where your weren't TDC when setting it, would the car still run fine, but have low compression?
obsolete is offline   Reply With Quote
cas, timing, won't start
