07-30-2010, 06:36 PM | #61 | ||
To life simple for u. It bolt straight up...
07-31-2010, 06:03 PM | #62 |
R.I.P. Aya, always love
Trader Rating: (215)
Feedback Score: 215 reviews
How did I miss this. This is wrong Early JDM 180sx's had 4.36's later Chuki and Kouki came with 4.08's just like USDM 240sx's only difference is the VLSD was a much more popular option and could be had without the ABS option unlike the U.S. 91 up option.
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
07-31-2010, 06:57 PM | #63 | |
Sorry I was referring to the CA18 180SX's which were the Early 180's Correct?
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
08-02-2010, 11:24 PM | #64 |
08-03-2010, 12:18 AM | #65 |
j30 front hubs fit s14 but some custom spacing is involved. front lock nut can be ground down with dremel and placed behind it and the threading is not long enough on spindle so cheap shims are needed to make up the extra space. abs ring must be cut off to . gogle it theres a thread on freshalloy with more detail. i did whole front 5 lug for 37 dollars + cost of rotors.def cheaper than oem s14 because everyone charges alot for them.junyards are your friend for j30s
08-03-2010, 12:58 AM | #66 |
Eagle talon turbo 89-98
440cc Injectors (direct bolt in to for KA-T or S20DET) is this really true no aftermarket fuel rail or anything? splicing and re wireing i suppose? |
08-03-2010, 04:09 AM | #67 | |
SR's have alot of AM Fuel Rails.
KA's have a few with AEM, ProjectNissan and a few others.
08-05-2010, 07:02 AM | #70 |
^^^^ dont post if your not sure.... please.....
DREW SLIDE TO SIDE WORLD WIDE Feedback!! http://www.zilvia.net/f/showthread.php?t=182673 661 sliders Gymkhana @ buttonwillow http://zilvia.net/f/south-western-st...-sessions.html >> Bakersfield Hook up thread << |
08-05-2010, 05:56 PM | #72 | |
I really didnt want to just because its not a big thread yet and people wouldnt get credit for adding their knowledge. and there is a search button
thanks
08-27-2010, 02:19 PM | #74 | |
I had a twin plate blitz clutch, and still used the oem slave cylinder.felt like an oem clutch except for the little pedal play room
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
08-30-2010, 07:14 AM | #76 |
^~lug nuts or studs? lug nuts, just search for 12x1.25. its been covered many times on here. depends on 4/5 lug and what parts you used.
S14 LCA is 15mm Longer then S13. |
08-30-2010, 10:24 PM | #80 | |
Trader Rating: (22)
Feedback Score: 22 reviews
EDIT FOR NEW KNOWLEDGE IN CASE ANYONE SEARCHING FINDS THIS: The stock '89-'90 240sx slaves are shitty and weak 11/16ths units. The '91-'98 240sx slaves are 3/4", same as the Z32 slaves, though, as stated earlier, the Z32 slave body is slightly different. What? Feels the same as stock to me...
-Kyle Last edited by soreballz; 01-09-2012 at 08:58 PM.. Reason: New knowledge! |
09-07-2010, 10:33 AM | #81 |
Maybe it has to do with me having a twin plate, I talked to 3 other guys who upgaded and felt it badly lol
09-09-2010, 02:31 PM | #82 |
You can use j30 uprights on s14's. The ebrake cable also works on an s14, just have to make extended brackets. You need to have a 1pc drive shaft, since where your brackets will end up are where the carrier bearing is. If you are using stock calipers just cut it or remove the ebrake cable since it has the same rear rotor as the z32. Great for people doing 5 lug and rear z32 brakes at the same time.
09-09-2010, 03:18 PM | #84 |
what about clusters? would the speedo and the rpm tach from a s14 to s13 sohc work?
my addition to the thread, sunroof handle on the s13 is the same as older pulsars or sentras |
09-13-2010, 03:31 PM | #85 |
Ok....My passenger side mirror fell off (glass only) so the replacement glass is around $20. So I went to Pick A Part and couldnt find any 240's with the mirror.....and found that a 90's Nissan Maxima has the same exact glass except it has a BLUE TINT.
Paid $8 and snapped it right in.....except this time I added some gorilla glue.... |
09-14-2010, 03:43 AM | #86 | |
3rd or 4th Gen?
Nissan Maxima - Wikipedia, the free encyclopedia
09-15-2010, 08:30 AM | #87 | |
Nismo240R
1989 to 1994..... I dont know if the whole mirror assembly is the same....but the mirror is an exact match....when you pop it off...use a flathead screwdriver to get behind it...take your time as to not crack the glass. |
09-16-2010, 07:43 AM | #88 | |||||
More good info.
I am about to go through and add all the newest info presented edited on the first page with the members User name for their contributions, or you could bitch at them if it doesn't work... lol.. Keep posting, Pics would be nice too. Quote:
This is an OEM compatable thread so he wanted to know a legitimate question Quote:
09-16-2010, 01:09 PM | #90 | |
Trader Rating: (313)
Feedback Score: 313 reviews
J30 studs are only 5mm longer than stock studs. |
