Old 05-24-2007, 09:12 PM   #1
drift_ricer
Banned from the Marketplace
drift_ricer is on the path to ruindrift_ricer is on the path to ruin
z32 maf and 550cc injector setup apexi safc help??
hi guys, I just installed t28 turbo, z32 maf, and sard 550cc injectors? does anyone know how to set this up using apexi safc II?
drift_ricer is offline   Reply With Quote
Old 05-24-2007, 10:56 PM   #2
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
dont half ass your tuning with just an safc. rom tune first or die. then if you feel the need for further tuning, then get the safc and a wideband with datalogging capabilities. done.
ch1873857 is offline   Reply With Quote
Old 05-24-2007, 11:03 PM   #3
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
safc2 is fine if you just want something to get by, but for real goodness, get a rom tune or standalone,
but to answer your question, it can be found by searching, z32 maf is something like 2 in 6 out in one of the menus, and as far as 550 goes, you need to tune down something to about 66% of what it normally runs, (put in slightly higher than 66% to be on the safe side), but you still need a tune, you def can get at least 250 whp with that setup
Wei240 is offline   Reply With Quote
Old 05-24-2007, 11:06 PM   #4
Big Bronze Rim
Big Bronze Rim's Avatar
Big Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the rough
As mentioned by the previous poster there are other options that are better such as a rom tune. At a minumum you will want to tune the car with some kind of wideband. As for a baseline, you will want to set airflow correction to -33% and set the MAF to 2in/6out for z32 maf. I would recommend reading up more on why devices that under report airflow for injector correction are not the best option in general (hint - overly advanced timing). Not saying that it can't be or hasn't been done with varying degrees of success, its just there are better options for slightly more money.
Big Bronze Rim is offline   Reply With Quote
Old 05-25-2007, 05:12 AM   #5
ch1873857
yeah of course there are better ways. megasquirt, aem ems, whatever. but you could get a freakin rom tune, a good rom tune. and be done. if its mapped right you shouldnt need adjustments with an safc. sorry im anti-safc. do what you want but do it right and save yourself a lot of time and hassle. good luck.
Old 05-25-2007, 09:03 AM   #6
Big Bronze Rim
I would say Im anti-AFC as well. Ive had one and ran pretty much the same setup as the original poster. While it crudely got the job done it had enough issues(driveability, cold starting, lack of timing adjustment over the stock maps which were forced into a crappy part of the timing map, etc) that I wanted something better and wound up getting a PowerFC and would never put another AFC in my car.
Old 05-25-2007, 09:11 AM   #7
ch1873857
imo opinion power fc isnt really needed unless your pushing some nce numbers with some nice parts. with his setup a stock engine contol unit will be able to handle it if it is retuned. a standalone isnt really needed in this case. this is just my opinion.
Old 05-25-2007, 11:01 AM   #8
johngriff
johngriff's Avatar
Why S-AFC Is a sure fire way to lose your setup.
http://www.zilvia.net/f/showthread.p...78#post1077578
as stated above, 2 in 6 out, minimum of -33%. and FYI, SAFC only does maximum of +/-50% (displayed), now wheather or not your tables at any given point allow for that much correction... WHO KNOWS!?!?!
Its an SAFC P.A.R.T.Y.
[email protected]
Old 05-25-2007, 11:25 AM   #9
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
ROM tune... Standalone.... fuck SAFC for the set up you have! actually fuck SAFC all together!
JadeCantDrift Blogspot
i need tires is offline   Reply With Quote
Old 05-25-2007, 12:10 PM   #10
ch1873857
well at least someone agrees with me. although i have heard a lot of good reviews for the greddy ultimate emanage. not the blue. but then again a rom tune is cheapest and safest and the easiest especially for your setup. and if your a diy tuning guy you might want to check out the pocket romulator and liveedit tuning program. real time tuning ftw..
Old 05-25-2007, 12:13 PM   #11
johngriff
johngriff's Avatar
Emanage Ultimate is actually quite the badass box.
Dont buy it if you want an easy install. It would be far easier to install a Haltech Flying Lead.
But, for the price, and the volume of dumb S*#* i've done with mine (methanol controller?!!?!?) its rocks socks for dirt cheap tunning.
[email protected]
Old 05-25-2007, 12:33 PM   #12
drift_ricer
thanks guys for the advices...I'm pretty much ran out of my money. plus my set up is just a basic and I only need under 300hp for drifting...any other ideas would be thankful!
Old 05-25-2007, 12:42 PM   #13
ch1873857
spend about a half a day reading, reading, and more reading about tuning factory eproms and do the shit yourself. in the end you will be able to tune that setup for 300hp for a mear $10 if you have the equipment. without...50 maybe?
Old 05-25-2007, 01:20 PM   #14
drift_ricer
I will bring my car to the shop to tune next week....
Old 05-27-2007, 01:28 PM   #15
ch1873857
reputation i recieved for this thread
lol shut the fuck up with that garbage
yay for you.
Old 05-27-2007, 01:48 PM   #16
s13gold
s13gold's Avatar
Trader Rating: (79)
s13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfection
Feedback Score: 79 reviews
theres a gb on ka-t.org for rom tunes...check it out.
s13gold is offline   Reply With Quote
Old 09-07-2020, 03:04 PM   #17
Sr20..247
Sr20..247 is an unknown quantity at this point
Guys I need help just start my sr20det back up after 5years of parking. My set up are z32 maf, SAFC2 and 550cc injectors and the car smoke.
Then I turn it off and the car won't start now.
I also have my hi throttle at -40 across the board and low throttle at -40 across board. Is this correct? ???
Sr20..247 is offline   Reply With Quote
Old 09-07-2020, 04:55 PM   #18
S14rebuild
Because the safc is horriable at controling those injectors at max adjustment. Ditch it and atleast go mail in tune...its only $400
Been sitting for 5 yrs might have more of an issue then ur safc/maf/injectors
Old 09-07-2020, 06:34 PM   #19
Kingtal0n
Kingtal0n's Avatar
Z32 maf and SAFC doesn't make any sense. There is no point to using that maf. Use a stock maf and 550cc injectors with SAFC first of all.
Then you need a wideband and dial in the a/f ratio.
Old 09-08-2020, 10:02 AM   #20
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Not to mention you need to set the IN - OUT for the Z32 maf for the Safc to read correctly. IIRC it's 2 In 6 out
Old 09-08-2020, 06:58 PM   #21
Sr20..247
I know safc is not a good way to go. But for right now I just need the car to start up and be able to drive around. As of right now Can anybody point me to the right way to set up the hi throttle...and ..lo throttle with the set up I got. I be appreciated
Old 09-08-2020, 07:03 PM   #22
S14rebuild
http://www.ka-t.org/forums/viewtopic.php?t=8089
Going wayyyyy back
Its for a ka24 setup but it will point u in the right direction
