Old 04-17-2021, 08:46 PM   #1
Jarom717
Jarom717's Avatar
Jarom717 is an unknown quantity at this point
PCV/Oil Catch can setup on s13.4 valve cover
Hey guys I've been trying to research this for over an hour now and there doesn't seem to be a direct solution. Everyone seems to do it a little different. Just got a s13.4 valve cover back from touge factory and they welded 10AN fitting on all the vent points including PCV.
I didn't really understand the pcv before because otherwise I might have kept it. I need to know how to run my catch can now without a pcv. I basically have 4 openings that need to be plugged or connected. The 3 on valve cover and the one on back of engine block.
Sent from my SM-G973U1 using Tapatalk
Jarom717 is offline   Reply With Quote
Old 04-18-2021, 08:17 AM   #2
Mikester
Mikester's Avatar
I can account for 3 of them:
Line from fitting on exhaust side of valve cover to hole in back of the block, line from exhaust side top of valve cover to your catch can, line from catch can to turbine inlet. As for the PCV, I have no clue why they’d do that, but they do make -10AN one-way check valves you can use to maintain the PCV.
Mike
Old 04-18-2021, 11:55 AM   #3
Jarom717
Jarom717's Avatar
Line from fitting on exhaust side of valve cover to hole in back of the block, line from exhaust side top of valve cover to your catch can, line from catch can to turbine inlet. As for the PCV, I have no clue why they?d do that, but they do make -10AN one-way check valves you can use to maintain the PCV.
Mike
Yeah I just bought a radium pcv valve and some fittings to make it work. I saw some people run a 3rd open line from it to catch can but I'd rather be safe I think and keep a pcv valve there.
Old 04-19-2021, 01:37 AM   #4
jr_ss
A lot of times the PCV is deleted altogether. Maybe they assume or it is standard practice and was missed in the details.
Old 04-19-2021, 09:23 PM   #5
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
On mine I have the block one connected to the one above it. The right side one going into the catch can. And the pcv back into the intake manifold
lexus baby
5t341tH is offline   Reply With Quote
Old 04-19-2021, 10:53 PM   #6
Jarom717
Jarom717's Avatar
That's how it typically is when you have a pcv valve still. Do you have one? You can't really just plug the pcv side into the manifold without the actual valve otherwise your pressuruzing your crank case.
Old 04-20-2021, 02:36 AM   #7
jr_ss
Install an inline check valve or a Krank vent.
https://www.haydensm6.com/kvp.htm
Old 04-20-2021, 04:49 AM   #8
Jarom717
Jarom717's Avatar
Already bought a radium one
Old 04-20-2021, 11:09 AM   #9
5t341tH
5t341tH's Avatar
Yea I am running a pcv. Previous owner of the cover welded on a female fitting of some sort and had a 10an fitting on there. Luckily it matched the pcv threads
lexus baby
Old 04-28-2021, 09:52 AM   #10
TheRealSy90
TheRealSy90's Avatar
Honestly I don't run catch cans with the 13.4 valve cover.
Such a good signature.
