Old 09-05-2008, 08:10 PM   #1
silvia919
silvia919 is an unknown quantity at this point
werid issue
i dunno wtf is goin on!!!..well i had to change my distributor so when i put it in.. and turned on the car it just turned on for couple of seconds and then shut off.. tried turnin it back on again and nuttin so me and my friend checked if it was gettin spark and no so we checked the coil and no spark at the coil put in a new coil and same shyt no spark at the coil... ummm what can it be? im kinda stump'd here my friend said to check the grounds... or it could be the ecu.. i dunno any suggestions ppl.. btw its a 89 single cam coupe and i check the fuse's and there all good
silvia919 is offline   Reply With Quote
Old 09-05-2008, 08:35 PM   #2
bbejj123
bbejj123's Avatar
bbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura about
when u say u replaced the distributor...do u mean the cap and rotor or the actual distributor with the crank angle sensor?
bbejj123 is offline   Reply With Quote
Old 09-06-2008, 02:29 AM   #3
silvia919
the whole distributor
