Old 06-09-2013, 11:27 PM   #1
z31na2t
z31na2t is an unknown quantity at this point
Z31 that drifts
This is my turd. I paid $1000 for it....sometime in 2010 I think. Dont know, had like 40 z31s. Anywhoooo....
It was a mess when I got it...solid, straight chassis...but the hood was banged up and the hatch glass was broken.
What a turd! lol
So I had what I believed was a cracked manifold...
It was a big crack...
Escalated quite quickly, actually.
Together:
Wait...rewind for a second. I forgot to mention, this was a factory automatic car. So another project was auto to manual swap. I did that in a day, no real pictures.
ugly mess though here:
New hood, blah blah
Front mount:
I'm going to skip all of the lame lowering spring stuff...and jump right to the fun.
Awesome CLSD (not stock) in factory Z31 diff case, with finned cover.
Best $25 ever spent:
Rolling shot from earlier this year...was on lame Suspension Techniques springs and Bilstein HDs
THEN...the good stuff:
Straight pipe back on:
The front wasnt quite low enough...went a touch lower. Rubs on fenders now...meh
These did not last long....
Random crap:
Engine/Engine Management:
A/B series VG30ET
'87 A/B series Crank Pulley, Water Pump pulley & PS Pump
Sentra 100A Alternator
'88T Injectors/Rails
'84T ECU
PRW-2 Ignition Transistor
'95 CAS
NGK Plug Wires
Z32 Fuel Filter
Walbro 255LPH HP Fuel Pump
Gutted Plenum /w Removable Lid
FMIC Setup /w 2.5" pipes
CM 3" Turbo-back /w test pipe
MBC @ 12psi
Ported Turbo-Automatic oil pump
SLC PurePlus 2 Wideband
Drivetrain
South Bend DXD Stage 3 Daily clutch (240mm, 530ft-lb rated)
FS5W71C (FS5R30A soon...)
CLSD
Suspension/Steering/Brakes
88T Front hubs
88T Front Rotors
88T Front Calipers
Poly Swaybar Bushings (Addco/Prothane mix)
Poly Zenki Tension Rod Bushings
Powertrix Coilovers (9k/7k)
I have Z32 calipers for it...need to buy rotors...I also have some brand new billet steering knuckles my friend and I make that I havent even put on yet....and theres other random crap I probably forgot...oh well.
Thats my turd. I rev it to 6500rpm daily and beat the piss out of it and it takes all of the abuse.
z31na2t is offline   Reply With Quote
Old 06-12-2013, 02:57 PM   #2
z31na2t
Autopower Roll Bar I got in a parts car....will work for now!
And another project...
Old 06-13-2013, 10:36 AM   #3
jesus94p
jesus94p is an unknown quantity at this point
My love <3 You need more kouki front ;-)
jesus94p is offline   Reply With Quote
Old 06-13-2013, 10:39 AM   #4
z31na2t
lol, no Kouki front.
Old 07-23-2013, 10:56 AM   #5
z31na2t
/business. lolol
Old 07-23-2013, 06:21 PM   #6
izzy-
izzy-'s Avatar
izzy- is an unknown quantity at this point
Nice update. The last pic looks like the car is smiling lol
izzy- is offline   Reply With Quote
Old 07-23-2013, 08:25 PM   #7
z31na2t
I totally didnt realize I didnt update the cars actual progress...I did a ton of other crap prior to the event Sunday.
I sold the Ronals and the roll bar and Z32 calipers however:
Installed:
MSA Solid 1" Sway bars
Control arms /w new ball joints (stock stuff for now)
Our Billet Steel steering knuckles
Not yet installed:
Solid Motor Mounts
Poly Diff Mount
Full Poly suspension kit
Longer wheel lug studs
So heres knuckle install:
Interior purtyness....because 80s Class? lol
Removed the stupid antenna that was for a 2-way radio:
Made the exhaust sit up closer to the bumper:
Then more stuff from Sunday:
Old 08-27-2013, 12:10 PM   #8
z31na2t
From the 18th:
So today I did the Poly trans mount finally, and poly tension rod bushings while I wait for ASCO's to become in stock again, or for Touge Factory to release theirs
Old 08-27-2013, 12:13 PM   #9
z31na2t
I almost forgot the shitty video my friend recorded with a potato:
IFD z31 turbo - YouTube
Old 08-29-2013, 10:01 AM   #10
z31na2t
Sooo...this happened:
So I figured it was a good time to install some stuff I've had for a while
Swapped out the cheapo boost gauge for an autometer I found
Then I threw a RSB-07 CAS in for giggles...absolutely nothing changed with how it ran.
Old 11-03-2013, 11:35 AM   #11
z31na2t
BIG Update alert
SO, while drifting I could only go for so long before it'd start to run warm because the maxima fans suck balls. I decided it was time to go to the good old trusty Taurus fan.
Step one was pulling the bumper cover
I got the maxima fan removed and the taurus fan in....the next issue was my intercooler routing. I had to cut some of the taurus fans shroud down so the pipe could go over it.
So i got it all back in and wired up and such.
I then noticed once the bumper cover was back on and the hood was shut...as soon as the fan turned on the car would want to stall or would stall. SO, the solution was a shield/cover for the air filter to keep the air/turbulance from the fan down....its not the prettiest, but it works! Function > form (for the most part)
And ready for the next weekend...
THEN...One of my cam seals started leaking...so I decided to take all this shit apart again..
Then started reassembly after changing the cam seals, and cleaning the oil off stuff
And back together...
Sunday 9/15! Had a blast, ran out of tires fast beause I didnt have many and one set was a bitch and came apart immediately. Had fun anyways. I really love the car with the ASCO solid motor mounts, poly trans mount and other random bits.
9/23 was fun...2 New Z31s! My friend Jeremiah bought a minty 87NA with 90k miles, and we went in on a 86T parts car with 102,000 miles which has less rust than 99% of all Z31s. He just wants the engine parts.
10/3 was rear brake time for drifty-car
Shit pads were shit:
After getting it all back together I adjusted the parking brake then I went and performed an e-brake 180 from about 60mph...so now we're all good with the e-brake functioning properly which should add to the fun.
A week or so prior I ordered a brand new 86GL dash harness so I could make use of my analog dash.
It came on the 4th.
I got all of the analog dash stuff installed...pictures later?
On the 19th I decided to do some tinkering and "maintenance"/modifications.
Z31Parts poly diff mount:
And some pictures from the event a few days prior
Not a spin:
The 27th was the last event of the season for me. I got ready late Saturday Night. I had mounted more tires than this:
Old 11-03-2013, 11:36 AM   #12
z31na2t
Day of:
Thats all for now...on the 28th I moved down to Illinois. Awesome car is awesome. Drive 100 miles, drift all day...drive 100 miles back - then make a 800 mile trip the next day.
