Old 02-21-2012, 02:27 PM   #1
jacobzking
jacobzking is an unknown quantity at this point
Ideal Fuel Pressure Regulator setting
I looked at just about all the FPR links and couldn't find an answer. I also read that Tomei has a calculator on their site but I couldn't find it. So anyone wanna take a stab at how to set a Tomei rising rate FPR for:
sr20det
walboro 255
555cc injectors
Thanks!
jacobzking is offline   Reply With Quote
Old 02-21-2012, 03:48 PM   #2
ultimateirving
ultimateirving's Avatar
43.5psi at idle. With vacuum connected 36psi without
Z32 with lq4 swap
Old 02-21-2012, 04:18 PM   #3
jacobzking
isn't that the stock setting for the smaller fuel pump?
Old 02-21-2012, 06:14 PM   #4
cotbu
cotbu's Avatar
First of all, are you tuned for those 555cc injectors?
Second there's is no second if you not tuned for those 555's!
This is you answer otherwise!
Old 02-24-2012, 12:10 PM   #5
jacobzking
yes, I'm tuned for the 555s. so my question is... isn't 43.5 the ideal pressure for the stock setup? if i'm running a different pump, and different injectors wouldn't i want to change the fuel pressure. isn't that the point of an adjustable fpr?
Old 02-24-2012, 01:28 PM   #6
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
You sir got it backwards... If you have an adjustable FPR. You will need to take off the vac hose from the fpr and dial it to 43.5 (3bar) and then attach the vac hose back. Depending on the condition of the motor not all will have the same vacumm so dont worry about that.
SoCal KA24DET/KA24ET Owners
<< Join the FB Group >>
GroundPerformance is offline   Reply With Quote
Old 02-24-2012, 01:34 PM   #7
GroundPerformance
Trader Rating: (44)
To best honest with you. If your running 555cc injectors and you its tuned for it. I really dont see the need for an adjustable FPR. Adjusting pressure will alter your tune and will not do you that much good at all. Only reason I would run one is if your maxing out those injectors and would want to get a little more fuel but this should be done during tuning. If you have a stock turbo running on baby boost you can spend that money elsewhere it actually counts.
Old 02-21-2013, 01:24 PM   #8
LiveLowSilvia
LiveLowSilvia's Avatar
LiveLowSilvia is on the path to ruinLiveLowSilvia is on the path to ruin
So would it be necessary to even have a FPR if I'm running a standalone system that's waiting to be tuned?? With 880cc injectors...
If I have total control with the AEM EMS, I shouldnt need an FPR, correct?
LiveLowSilvia is offline   Reply With Quote
Old 02-21-2013, 02:20 PM   #9
CurleyMerkin14
CurleyMerkin14's Avatar
CurleyMerkin14 is an unknown quantity at this point
those are large injectors idk what your running that needs them but...if your running lean on those injectors and they are maxed out electronicaly then an adjustable FPR would be added to produce more pressure in the system to give you the required fuel for your application ... that's kinda the simplest i can explain that
CurleyMerkin14 is offline   Reply With Quote
Old 02-21-2013, 03:06 PM   #10
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
adjustable FPR is good. set it to stock like these guys suggested.
however, i don't think you need a rising rate FPR. you should use a regular FPR, and handle all the fueling control with your ecu.
96Turbo is offline   Reply With Quote
Old 05-01-2020, 10:48 AM   #11
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the rough
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
Bump. I have the same upgrades as the OP, was wondering if a aftermarket FPR is necessary or not
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 05-01-2020, 11:16 AM   #12
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
Thank you for the bump, this thread is fucking priceless.
mechanicalmoron is offline   Reply With Quote
