Old 05-14-2008, 12:25 PM   #1
BustedS13
BustedS13's Avatar
KA24DE Emissions Removal FAQ
THIS IS A WORK IN PROGRESS, I WILL BE FILLING IN ALL GAPS. PLEASE DO NOT DELETE, THANK YOU!
I'm returning my s13 to the street, and in the process, am removing all emissions nonsense. Two reasons:
1.) Troubleshooting the KA, in my experience, is consistently a NIGHTMARE because of cracked/leaking vacuum lines.
2.) Emissions for OBD1 in my area consists of a visual for the carbon cannister, cat, and EGR piping, if they even bother to check. when my car goes in for inspection, it will have the shell of a cat bolted to a test pipe, and none of the other crap. we'll see what happens
While searching here I found a lot of information but had to do some digging. I'm putting all information here in this thread so that I can have a set of reference material, and so that others can benefit later. This will also, in time, contain my own experience. I will attempt to give credit for every quote i pull. Let's begin:
EGR
http://forums.nicoclub.com/zerothread?id=109345http://www.project-mayhem04.com/EGR%20Removal.html
pretty nice writeup concerning most of the intake mani, not just the EGR piping. recommends not disturbing the PCV. i beg to differ
some recommend replacing the EGR temp sensor with a resistor:
Originally Posted by SilviaSativa
The resistor is replacing the EGR Temp sensor. Cut the wires off the EGR temp sensor, solder one end of the resistor to one wire, repeat on the other end. I believe it is a 10k-ohm, 1/4 resistor
AIV (PAIR)
description
Pulsed Air Induction Reed Valve - for all intents and purposes, it's the smog pump. Its job is to introduce fresh air into the exhaust upstream of the cat/con during deceleration and extended periods of idle to help keep the cat "lit off" (at operational temperatures). The PAIRV disappeared from the engine in '94, with Nissan citing engine improvements being responsible for no longer needing it.
removal
PCV
description:
The PCV system is intended to
relieve the crankcase of any positive pressure by allowing it to vent through the free flow of air, either into or
out of the crankcase. Prior to advent of emissions, the crankcase was just vented through a breather on the
valve covers or intake manifold to the environment. Emissions requirements necessitated a “cleaner” way to
vent the crankcase to prevent the hot oil laden vapors from damaging air quality. That led to the inclusion of
today’s modern PCV systems. Current PCV systems are still pretty simple, consisting of an air inlet, a valve,
and an outlet. The air inlet (the vent tube) supplies filtered and metered airflow into the crankcase. The PCV
valve, which when opened by either internal intake manifold vacuum or positive crankcase pressure, vents
into the intake manifold, allowing the now oil contaminated but otherwise filtered and metered crankcase ventilation
airflow to be consumed by normal combustion processes.
removal:
http://www.ka-t.org/forums/viewtopic...er=asc&start=0
method removes more vac lines, plugging the intake mani holes.
carbon cannister
post removal issues
EGR
Originally Posted by BigVinnie
Yeah you got that right and the fact that exhaust gas no longer takes the space of air in the cylinder chamber during compression. It also completly FUCK's up the O2 signal.
That also means that it retards ignition timing so the engine technically will run like shit.
A retuned ecu will fix that problem by changing the A/R ratio. Or even a piggy back will work by fooling the MAF signal to the ecu that it is getting less air than it really has (somewhat correcting the problem by shrinking the pulse width of the injection in the cycle).
KA's run rich with there stock tune to begin with. The stock tune increases fuel richness by 7% more fuel than air at low rpms. Poor stock tune along with removal of smog equipment is one rich KA.
reasons to remove equipment
AIV (PAIR)
Originally Posted by nastjuid View Post
The AIV (PAIR)... Was actually removed in the S14s because all they did was cause problems. The valve gets stuck open, and the sensor element in the MAF gets coated and you start having problems that don't diagnose a like MAF misread. Or something along those lines.
if anybody has anything to add, please do so!
Old 05-14-2008, 02:08 PM   #2
John_R
John_R is making a name for him/her selfJohn_R is making a name for him/her self
Great thread. +1 for sticky
John_R is offline   Reply With Quote
Old 05-14-2008, 09:57 PM   #3
frosti108
frosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nice
Send a message via AIM to frosti108
gotta love emissions removal... i removed everything from my ka24e, and am in the process of doing the vg30e in my s12... all are a bit different, but have most of the same parts and systems. only thing i usually leave on is the part that has the idle screw lol
for valve cover breathers, best options are usually to either run it to atmosphere with a filter (easiest, works fine, but no vaccum) run it to the intake with a catch can (gets vaccum, minimal nastiness gets back in the intake) or if you have a welder, run it to the exhaust at an angle, with a check valve after the o2 sensor (like a drag car, takes advantage of a venturi effect in the exhaust, no worries of sludging up your intake)
i just run atmospheric breathers because im lazy
Goodnight
frosti108 is offline   Reply With Quote
Old 05-14-2008, 10:07 PM   #4
de3zy
de3zy is an unknown quantity at this point
good write up
de3zy is offline   Reply With Quote
Old 05-14-2008, 10:52 PM   #5
Devens240
Devens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really nice
sticky thisssssss
Devens240 is offline   Reply With Quote
Old 05-14-2008, 10:57 PM   #6
Fries
Fries's Avatar
+1 FOR DESTROYING OUR AIR! Cannot wait for this to be fully updated so I can join you in the War against Gore. AlGore that is.
Old 05-14-2008, 11:06 PM   #7
Oo_Skyline_oO
Oo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud of
Send a message via AIM to Oo_Skyline_oO
I don't see the purpose of removing it in the first place..o_O if you're going to go through the trouble of all of this, might as well just replace all vacum hoses with new ones, and it feels great to have a car that runs clean and legit.
Oo_Skyline_oO is offline   Reply With Quote
Old 05-14-2008, 11:17 PM   #8
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
http://forums.nicoclub.com/zerothread/254273
aiv faq
you will need the aiv for smog in british columbia. or anywhere that has idle test other than california. california has a different computer that keeps the o2 sensor in the loop during idle so you can get away without the aiv. aiv doesnt help smog reduction during driving.
surreybc is offline   Reply With Quote
Old 05-15-2008, 12:27 AM   #9
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
Ya while its nice he is faq'ing all the emissions stuff it sucks he is removing it because it really does not take that much HP away from our engines. Go on polluting busteds13 I hope you choke on it.
New Video
Buy my mounts!
Old 05-15-2008, 12:34 AM   #10
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
AHH THIS IS AWESOME!!!
i just did all of this though haha but im glad i know i did it right
+1 for you man
HS13KLS is offline   Reply With Quote
Old 08-13-2008, 07:24 PM   #11
Om1kron
Om1kron's Avatar
great post yet again!
Wayne Edwards
https://om1kron.blogspot.com
Old 08-14-2008, 12:10 AM   #12
i8yourfwd
i8yourfwd's Avatar
i8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfection
Send a message via AIM to i8yourfwd
great post, great info!
http://jaythroughglass.blogspot.com
S13SilviaGirl: Mel are you that big?
i8yourfwd is offline   Reply With Quote
Old 08-19-2008, 04:36 PM   #13
twastheglow
twastheglow's Avatar
twastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nicetwastheglow is just really nice
Send a message via AIM to twastheglow
Does all that have to be removed or can I just block off the egr and deal with it's vacuum lines?
*mike*
twastheglow is offline   Reply With Quote
Old 08-19-2008, 04:39 PM   #14
karl wasabi
karl wasabi's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
I have an EGR block off plate if anyone wants to remove their emissions. It's for a dual cam motor. PM me if you are interested.
Really good stuff...
karl wasabi is offline   Reply With Quote
Old 08-19-2008, 04:41 PM   #15
twastheglow
I have what I need on the way. I just need to know if I have to remove all the other stuff. If I just cap that egr pipe and seal off any vacuum lines that need attention, wouldn't that suffice? Can't I leave the other stuff intact so my car will be drivable?
*mike*
Old 08-21-2008, 12:47 AM   #16
BustedS13
BustedS13's Avatar
i blocked mine off by sandwiching a piece of license plate between the mani and a piece of the egr valve... i've never appreciated our hand-crank bench grinder as much as when i made that.
Old 08-21-2008, 12:59 AM   #17
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
I assume we should change spark plug heat range after removing the EGR system?"
Bigsyke is offline   Reply With Quote
Old 07-22-2009, 03:23 PM   #18
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Bump.
What is this?
The hose goes to the same thing as the EGR hose. Is it necessary, or can it be plugged?
Thanks for any info.
Old 07-22-2009, 03:53 PM   #19
93nismo
93nismo's Avatar
93nismo is an unknown quantity at this point
when i put on my header last wek i cut the egr line and its currently plugged with a rubber hose and a big ass bolt(afro enginering at its best) anyway, when i take the egr system off, probly in a week or 2, were can i take it to get the ecu tuned? am i gunna have to go to a performance shop? or will most places do it. i only really ask because i kinda wonder if regular shops will bitch about the emissions removal or something and refuse to do it.
93nismo is offline   Reply With Quote
Old 07-22-2009, 03:56 PM   #20
Matej
Trader Rating: (39)
Came across this on KA-T.org.
Originally Posted by Corey
I am working on removing all the emissions garbage now so I labeled a few of the pictures in here to help me. Maybe it will help you guys too. Thank you to everyone who posted the original pictures.
color key:
Back of the engine:
Lower intake manifold:
Upper intake manifold:
key:
A: Exhaust Gas Recirculation (EGR) Outlet
B: Vacuum Hard Lines to PAIRC Solenoid Valves (Atmospheric and Vacuum) and Canister Vacuum
C: EGR Valve
D: EGR Control (EGRC)-Back Pressure Transducer (EGRC-BPT) Valve
E: Fuel Pressure Regulator
F: Swirl Control Valve (SCV)
G: SCV Control Solenoid Valve
H: EGR and Canister Control Solenoid Valve
I: Idle Air Adjusting (IAA) Unit (Idle Air Control Valve (IACV)-Auxilary Air Control (AAC) Valve, IACV-Fast Idle Control Device (FICD) Solenoid Valve, Idle Adjust Screw)
J: IACV-Air Regulator
K: Solenoid Valve Bracket
L: Heater Return Hose
M: IACV Line
N: Canister Purge Line
O: Collector Coolant Line
P: Positive Crankcase Ventilation (PCV) Lines
If I made any mistakes let me know please so I can fix it!
Old 07-25-2009, 07:11 PM   #21
Chad4061
Chad4061's Avatar
Chad4061 is an unknown quantity at this point
good info...gonna be removing my egr soon. might be doing the pcv delete as well
Chad4061 is offline   Reply With Quote
Old 07-26-2009, 06:57 AM   #22
projectRDM
projectRDM's Avatar
Bump.
What is this?
Just a vacuum line, usually branches off but it definitely feeds the FPR for certain. So make sure it's still connected. Whatever it ties into can be bypassed though.
FORMERLY R240NA
Old 02-09-2011, 11:49 PM   #23
trigun808
trigun808 is an unknown quantity at this point
What Corey found, is that thread still alive? is there still pictures available?
trigun808 is offline   Reply With Quote
Old 03-25-2011, 10:16 AM   #24
Likethunda
Likethunda's Avatar
Likethunda is an unknown quantity at this point
The original post mentioned that the car would run like SH*t if the EGR was removed... because it would start running rich, and would need some kind of Retune
soo, why is everyone removing EGR again? and is this true^^^^^
Likethunda is offline   Reply With Quote
