Old 03-27-2008, 12:25 PM   #1
imarvyn
imarvyn is an unknown quantity at this point
SR need s13 help
so i have an s13 w/sr20det and it was working perfectly fine, until it died on me a couple of days ago. so when i start it theres like a loud spark sound, but it starts. at first the engine's idle was hectic, as in it would try to save itself from dying, with black smoke coming out of the exhaust. people were telling me it could be the maf, but still same problem. any suggestions?
imarvyn is offline   Reply With Quote
Old 03-27-2008, 12:29 PM   #2
sumoboi7
sumoboi7's Avatar
sumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to all
did u try n clean the maf. i think black smoke means u r running rich. if cleaning the maf with maf cleaner dusnt work try checking ur o2 sensor. if its dirty it will send weird signals to ur ecu causing ur car to run rich.
RIP: black '89 s13 hatch
New: white '90 s13 hatch
sumoboi7 is offline   Reply With Quote
Old 03-27-2008, 01:47 PM   #3
SDS13COUPE
SDS13COUPE's Avatar
SDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant future
Also check your IC pipes. Black smoke clouds coming out usually mean boost leak.
SDS13COUPE is offline   Reply With Quote
Old 03-28-2008, 05:18 PM   #4
JP180SX
JP180SX is an unknown quantity at this point
Do you still have the stock plastic front fender gaurds in? if not check to see if your ECU got wet, this maybe your problem.
JP180SX is offline   Reply With Quote
Old 03-29-2008, 01:10 PM   #5
imarvyn
fluck my ecu isn't blinking, do you think i need a new one? but im pretty sure its boost leak or that my turbo blew..
Old 03-29-2008, 02:55 PM   #6
tha240star
tha240star is making a name for him/her selftha240star is making a name for him/her self
yeah it sounds like your maf like they said, or a vacuum leak. it could be as simple as a missing ground wire also.
tha240star is offline   Reply With Quote
