04-25-2016, 06:22 AM | #6121 |
What swaybar spacers are you guys using to clear the oil pan with oem fitment swaybars?
I don't want to purchase sikky just yet.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
04-25-2016, 07:05 PM | #6122 | |
04-25-2016, 07:19 PM | #6124 |
04-25-2016, 09:07 PM | #6127 |
Yea, I'm using the 2jz mishi thermostat.
And of course that is with the fans on. Why would anyone turn their fans off? Lol I always have fans on. Don't even have a switch to turn them off. They are simply on a key on power source through a pair of 50amp Spal relays. I'm also running a 200A alternator to keep up with them.
-Kyle |
04-28-2016, 06:44 AM | #6129 |
i pulled my thermostat out and it looks like i have a 68 degree one in there already, cool.
also.. the power steering line.. im assuming the banjo bolt threads are same as a 240sx as ppl seem to be using a ka/sr PS high pressure line? |
04-28-2016, 09:29 PM | #6130 |
As far as I know they are both 16x1.5 at the pumps, but I couldn't tell you the length as I've done nothing but remove any KA's I've come into contact with lol
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
04-29-2016, 05:49 AM | #6131 |
grabbed a enthuspec line. really nice quality and yes the thread pitch are the same. the length seems like it will be fine but have to test when the motor is back in the car
05-02-2016, 06:00 PM | #6135 |
Just got my car running and my car is running lean, my fuel pressure is reading at 20PSI when idle and would not go pass 21PSI when I try to crank up the PSI. I try adding more voltage to my pump by tapping a power wire from my alternator to my pump and still get the same result. My car is not leaking fuel and all my parts are brand new. Do you guys know what would cause my fuel pressure not to build up?
Fuel setup • FIC fuel rail • Fuel line o -8 sending braided fuel line o -6 returning braided fuel line • Fragola Performance Systems Inline Fuel Filter • Bosch 2150cc injectors • Walbro 450 LPH fuel pump • Aeromotive fuel pressure regulator
kuv yoj hmong ey koj ney??? Last edited by Sifudrifter; 05-02-2016 at 06:32 PM.. Reason: typo |
05-02-2016, 09:46 PM | #6136 | |
I'm suspect the pump, but its tough to say over the net. |
05-03-2016, 12:09 AM | #6137 |
Yes, I try using my younger brother 320LPH fuel pump and my fuel pressure went down to 10PSI. I also try using my brother FPR and still get the same result.
kuv yoj hmong ey koj ney??? Last edited by Sifudrifter; 05-03-2016 at 01:36 PM.. |
05-03-2016, 06:37 PM | #6139 | |
kuv yoj hmong ey koj ney??? Last edited by Sifudrifter; 05-03-2016 at 07:29 PM.. |
05-05-2016, 07:20 AM | #6145 |
05-05-2016, 06:55 PM | #6146 |
Trader Rating: (53)
Feedback Score: 53 reviews
Anyone have the Maverick revision 2 kit? I'm wondering how thick the plate is? I wanted to ask here before emailing them.
: @e_lemonation |
05-07-2016, 08:42 AM | #6147 | |
that and a non cut bellhousing made it hit my firewall/ trans tunnel, hammering wouldnt clear it as much as i wanted so i cut it out and welded in some sheet metal for more clearance. fits much better now. |
05-07-2016, 08:44 AM | #6148 |
05-07-2016, 10:33 AM | #6149 | |
Get out your volt meter and row thru the gears to see what it is...
05-07-2016, 11:24 AM | #6150 | |
Trader Rating: (53)
Which mounts are you using?
: @e_lemonation |
