![]() Join Date: Jul 2005
Yes, the pcv needs to be fixed right away. emergency. you are pressurizing your crank case above atmospheric pressure and leaving the gasses of combustion no where to run. They are putting pressure on your oil seals.
also welcome to 1997 |
#8 |
![]() Join Date: Jan 2010
![]() ![]() ![]() ![]() Feedback Score: 10 reviews
anyone have a pic on the CORRECT way it should be routed??
http://www.240sxforums.com/forums/rb...ject-s-rb.html |
#9 | |
Yes the catch can is "vented" but to where? the atmosphere. And what is the pressure in the atmosphere where he is? lets say sea level, 14.5PSI (pick any number) Now, for molecule to move from the engine to the "catch can" there MUST be a greater pressure at the crank case. So if the pressure is higher at the engine's crank case than in the atmosphere we say it is "pressurized", that is, a higher pressure with respect to the atmosphere. That means during boost ALL of his oil seals, including piston rings, front main, rear main, everything is being pushed outwards towards the atmosphere. And to tie a pretty knot in this detail, a common theme for V8 engines producing 600+ horsepower is to provide additional sealing/strengthening of those oil seals, such that an external belt driven vacuum pump can provide a high vacuum situation inside the crank case... for many reasons, among them, additional power. The point is those oil seals would get sucked right into the engine, or blown out, depending upon the pressure in the crank case. Having a slight vacuum provided by a functional PCV system helps to keep the oil INSIDE the engine, as one benefit, and there are others as well. I would run the forward line to a can and then back to the turbocharger inlet, and the rear line directly into the downpipe. You will want a restrictor in the forward line if doing it this way. Like the factory uses. |
#10 |
pics pics pics!!
#11 |
http://www.nicoclub.com/archives/rb-...her-guide.html
http://forums.nicoclub.com/how-to-se...b-t403897.html into the exhaust into the turbocharger ![]() I recommend both at the same time, use a restrictor on the turbo side, use the shortest lines possible, angle the fittings properly. |
#13 |
ahhhhh!!!!!!!!!
#14 | |
#15 |
That does seem like someone's poor understanding of theory, venting it into the exhaust and hoping the venturi effect will suck out extra gas would require a huge conical exhaust with literally no restriction... something I doubt many people can duplicate
With a catch can stripping oil from the vapour, it could be routed back in front of the turbo to give true suction, but if the turbo sucks too much, that could end up sucking more oil vapour out of the crankcase Leaving it open to atmosphere as in the first post avoids most of the pitfalls, without being particularly good or bad, any blow-by pressurization is minimized, but no extra ring sealing is generated |
#16 | ||
It was just a random google image to show how to route the lines. You are correct in your observation that the atmosphere should NOT be allowed to enter the PCV system, except right at the turbocharger inlet, and even in that place there are counter measures (several restrictive points on the OEM design) to prevent the atmosphere from having a large influence. Quote:
Leaving it open to the atmosphere is a worst case scenario. It is literally the least amount of work and plumbing. |
#18 |
I have one for you, not my car but a close friend's
![]() ![]() ![]() Stock RB25 neo Engine Precision PT 6776 turbocharger 25PSI + race gas 550~ RWHP Lasted 35~ runs then the oil pump flew apart |
#19 |
He also had this
![]() ![]() ![]() stock engine stock skyline ![]() The RB25 is a taxi-cab engine, I would never try to squeeze power out of one, there are better options in the same price range. It's different if you already have one and you don't care if it flys apart. But how did you even wind up with it to begin with? poor planning. |
#20 | |
#21 |
Most of the shit that guys posts is retarded, dont pay any attention to him.. Strange you damaged the oil pump, that engine should have the longer oil pump drive on the crank, Neo's are great engines, stronger than normal Rb25's and solid lifter! Stay off the limiter and make sure that Crank pulley is torqued properly and in good shape!! Last edited by Sforteen; 10-16-2014 at 08:46 PM.. |
#22 |
